bore out tb/im good for boost?
Guest
Posts: n/a
i have 2.5" ic piping so would i just match that with the tb size? or would it be more beneficial to go bigger than my piping?
also would i port match the tb size to my intake manifold?
going to be using stock IM and TB just porting them
would i need a new tune after installation?
Yeah, Honda heads and IM flow pretty decent stock and can support low-medium boost just fine. It's when you're boosting so high that the stock IM can't flow enough to support it...but then you loose low-end power from the oversized flow path.
Then you have something like a Venom or Golden Eagle IM made for boost that has a totally different design....
