Changing valve guides
Old Aug 24, 2006 | 05:19 PM
solid gsr's Avatar
Default Changing valve guides
I have 2 new valve guides for the head i'm working on you usually just wack the old ones out, is that all you have to do on a b16 head? or is there a trick to it. I just don't want to bend/break anything i don't want to.
Old Aug 25, 2006 | 12:02 PM
solid gsr's Avatar
nvm i did it betweent the oven, the freezer and a big hammer with homemade punches
Old Aug 25, 2006 | 01:57 PM
PyroProblem's Avatar
Default Re: (solid gsr)
Snap-on sells a nice driver with a 7mm pilot, perfect for b series valveguides.
Use it with an air hammer/rivet gun...
Works great if you ever have to do it again!
Old Aug 25, 2006 | 05:21 PM
NonovUrbizniz's Avatar
Loved
Technically you're supposed to heat the head to 180 or 200 degrees or something so that the aluminum expands but the bronze does not... that way the both go out easier without damaging their seats and also the new ones go in easier and have a permenant strong seal.
Old Aug 25, 2006 | 08:09 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: (NonovUrbizniz)
why risk doing it wrong and really ******* up your head and just take it to a machine shop
Old Aug 26, 2006 | 07:12 PM
:Josh:'s Avatar
Default Re: Changing valve guides (solid gsr)
a valve job is always necessary after changing guides
dominate9
Apr 14, 2020 02:10 PM
80 dolla crx hf
Sep 8, 2014 01:28 PM
unknown0001
11
May 11, 2007 03:43 PM
JDM turbo DC
Jan 30, 2007 01:31 AM
BDRphaSe2
May 27, 2006 06:13 PM
