Stainless Brake Line Problem
Old Aug 23, 2006 | 05:59 PM
jvtec95's Avatar
Default Stainless Brake Line Problem
I got a set of NSX calipers and stainless steel lines, however, I cannot get the stock rubber lines off of the hard lines. I've tried PB blaster, heating them, everything! They are almost bonded to the stock rubber lines fittings by corrosion. Is it possible to cut the hard line just above the fitting and put a new threaded fitting on?
Someone help me out who's had this problem before!
Old Aug 23, 2006 | 07:16 PM
all-mtr-teg's Avatar
Default Re: Stainless Brake Line Problem (jvtec95)
if you cut the line, wouldn't it be a pain to flare the hard line in its awkward position?
Old Aug 23, 2006 | 08:07 PM
jvtec95's Avatar
Default Re: Stainless Brake Line Problem (all-mtr-teg)
I imagine it definitely would be, but I don't know if I have any other options.
Has anyone had to do this, is it even possible?
Old Aug 23, 2006 | 08:19 PM
Muckman's Avatar
Moderator in Chief
Its just a flared fitting. You'd need a tube flaring tool and the right size fitting. I think finding the fitting would be the hardest part.
Old Aug 24, 2006 | 02:45 PM
jvtec95's Avatar
Default Re: Stainless Brake Line Problem (Muckman)
anyone know where I can find the flared fitting I'd need? Also, where's a good place to get the flaring tool?
Thanks.
Old Aug 24, 2006 | 04:33 PM
PrinceAli132's Avatar
I believe harbor freight sells the tool. You can also try autozone and see if they have it as well.
Also, look more into the flaring, because i believe honda's use a double flare or something like that.
Ali
Edit - here are some links i found;
https://honda-tech.com/zerothread?id=1251907
https://honda-tech.com/zerothread?id=1436445
https://honda-tech.com/zerothread?id=1251909
https://honda-tech.com/zerothread?id=937028
Old Aug 24, 2006 | 05:13 PM
jvtec95's Avatar
Default Re: Stainless Brake Line Problem (PrinceAli132)
Thanks much!
beav
Nov 26, 2007 09:28 AM
JCracer723
Mar 9, 2007 06:52 AM
93civic2005
Jan 14, 2007 01:18 AM
MugenB16A2
Jun 21, 2004 09:01 AM
turbospool
Aug 10, 2003 11:38 AM
