TPS voltage
Old Aug 13, 2006 | 07:34 AM
garyc17's Avatar
Default TPS voltage
Can someone measure their TPS voltage when the throttle is closed on their DC2R? I have searched hard on this forum and it seems the ideal range should be 0.45v and 0.5v. I am not so sure on that now after reading a link to http://www.integra.orcon.net.nz/tps
It is mentioned at the bottom of the page that the voltage varies between models. The writer mentioned that his stock voltage was measured at 0.32v. I am trying to solve a fluctuating idle problem. Lastly, how accurate is the voltage when read of my hand held PowerFC commander?
Old Aug 13, 2006 | 09:20 AM
slo blue's Avatar
Default Re: TPS voltage (garyc17)
the voltage when closed is 0.45-0.5 wide open is 4.9-5.0 when using any type of system that can read values from sensors they are usally accurate.
Old Aug 13, 2006 | 10:06 AM
b19coupe's Avatar
99% of unmodified Integra TPS sensors read 0.49 volts exactly at idle.
Old Aug 14, 2006 | 07:49 AM
garyc17's Avatar
If I get a reading with slight fluctuation between 0.47v and 0.48v, is it okay?
Old Aug 14, 2006 | 07:54 AM
b19coupe's Avatar
Default Re: (garyc17)
Yes.
Old Aug 15, 2006 | 02:16 AM
garyc17's Avatar
Okay. Thanks.
Kid-jdm-teggy
Jan 18, 2014 07:20 AM
Throwback23
May 4, 2010 09:33 PM
the.hamburglar
Jun 9, 2007 11:53 AM
94Integra_Ls
Feb 14, 2007 10:01 PM
turbo Si
Jun 10, 2003 07:52 AM
