tps voltage at idle?
Old May 8, 2007 | 10:12 PM
the.hamburglar's Avatar
Default tps voltage at idle?
i still have this messed up idle issus of it surging between 1000 and 1200. i have about .51 volts at the tps at idle. i read its supposed to be about .45. would it make this much of a differnece or should i keep looking somehwere else?
also, would a poor battery be the problem as well? my battery will die after sitting for about 10 minutes with the lights on and engine off. im thiking maybe its not able to keep sending that voltage to the tps. thanks
Old Jun 9, 2007 | 11:53 AM
omniman's Avatar
Default Re: tps voltage at idle? (the.hamburglar)
you need to have about .45 volts closed throttle. also if the volts are too far from .45 it can cause idle problems. TPS sensors also go bad from time to time. if you ever need a new one we have them
Kindled Light
32
Mar 1, 2019 06:06 PM
.hawaii
Nov 13, 2009 05:10 PM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
Brian_92GSR
May 31, 2004 03:57 PM
b16a1civichb
Jun 4, 2003 04:24 PM
