Throttlebody PLate supposed to be sealed?
Old Aug 11, 2006 | 06:09 PM
crxsiperf's Avatar
* B A N N E D *
Default Throttlebody PLate supposed to be sealed?
Is the throttlebody plate /butterfly supposed to be sealed when idleing, and the car stays running solely by the IAC valve? Im having problems with my idle with my throttlebody and i need to know if my butterfly plate is not completely sealing or if its somethig else , its an aftermarket throttlebody .
Old Aug 11, 2006 | 06:12 PM
Miracle's Avatar
Default Re: Throttlebody PLate supposed to be sealed? (crxsiperf)
Does it idle high at 0% throttle when in neutral?
If not, then you have nothing to worry about. If it does, check your preload on the cables.
Old Aug 12, 2006 | 10:39 AM
crxsiperf's Avatar
* B A N N E D *
Default Re: Throttlebody PLate supposed to be sealed? (Red_EM2)
Well the thing is , if i hold the throttlebody up to the light i can see light the entire way around the plate , meaning a good bit of air can go through there. Its a bdl throttlebody , 68mm , i may just get an edelbrock or something
aichinose
Apr 9, 2015 05:37 PM
victor068
Mar 3, 2007 09:47 PM
crxsiperf
Aug 12, 2006 11:43 AM
crxsiperf
Aug 12, 2006 10:38 AM
crxsiperf
Feb 2, 2006 09:03 PM
