Found reason why I was smoking-
Old Aug 9, 2006 | 05:08 PM
black99x's Avatar
Default Found reason why I was smoking-
When I took my block apart I found piston number 3 had cracked in between the rings- This tore up the cylinder wall a little but does not seem that bad. Is it more likely I will need to bore it out or can I get away with a hone? How much does it cost to hone a block at an average machine shop? $100 $200??? I will post some pics when I get a chance-
Old Aug 9, 2006 | 05:56 PM
black99x's Avatar
Default Re: Found reason why I was smoking- (black99x)
Old Aug 9, 2006 | 06:00 PM
fmrprojects's Avatar
title is funny. and your answer is cause you are addicted. but anyways if its a stock block, then you better off buying a used one in good shape and swap it in. saves time and money. unless you have plans for it
Old Aug 9, 2006 | 06:10 PM
anek's Avatar
i believe sleeving it could be done?
Old Aug 9, 2006 | 06:17 PM
black99x's Avatar
Default Re: (anek)
Why would I sleeve the block or get a new block when I can bore my block out?
Old Aug 9, 2006 | 06:21 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (black99x)
i found out the reason i was smoking too..... cuz im dumd.... oh wait cuz i stress... kid, wife, buisiness ya know
Old Aug 9, 2006 | 06:44 PM
anek's Avatar
ah my bad haha thought you had a cracked block, i see now it is a piston lol
Old Aug 9, 2006 | 07:13 PM
gldndrgn14's Avatar
Default Re: (WHITFIELD-TUNED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHITFIELD-TUNED &raquo;</TD></TR><TR><TD CLASS="quote">i found out the reason i was smoking too..... cuz im dumd.... oh wait cuz i stress... kid, wife, buisiness ya know </TD></TR></TABLE>
stress is an excuse for your addiction. you fiend. ahha
Old Aug 9, 2006 | 07:38 PM
black99x's Avatar
yeah I think I saw you on tv one day- You need to keep smoking... lol
Old Aug 9, 2006 | 08:06 PM
DYNO-PRO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black99x &raquo;</TD></TR><TR><TD CLASS="quote">yeah I think I saw you on tv one day- You need to keep smoking... lol
Old Aug 10, 2006 | 10:37 AM
black99x's Avatar
What is the max more for a gsr block with 81mm pistons? 81.04??
Old Aug 10, 2006 | 11:01 AM
SkankyEJ7's Avatar
Default Re: Found reason why I was smoking- (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">title is funny. and your answer is cause you are addicted. but anyways if its a stock block, then you better off buying a used one in good shape and swap it in. saves time and money. unless you have plans for it</TD></TR></TABLE>
yeah i was gonna say caus ethere a cigerette in your mouth
Old Aug 10, 2006 | 12:15 PM
black99x's Avatar
Does anyone know the max bore with 81mm pistons 81.04?
Old Aug 10, 2006 | 12:47 PM
bluelxfodo's Avatar
max bor on a 81mm block is 82mm.. anything after that is trash.. unless you spend the money and get it sleeved
Old Aug 10, 2006 | 02:16 PM
black99x's Avatar
Default Re: (bluelxfodo)
I'm talking about with a 81mm piston.
Old Aug 10, 2006 | 03:06 PM
black99x's Avatar
Need answer
May 20, 2008 09:32 AM
Peter Brady onlyonweekndz
Nov 22, 2007 09:47 PM
jdm_SirG
Aug 27, 2006 06:46 PM
MAPU
Mar 4, 2006 09:51 PM
JDM2ndGen
Mar 7, 2004 04:05 PM
