block question?
Old May 19, 2008 | 10:34 PM
96733's Avatar
Default block question?
got a type-r block that has excessive blow by. apparently the piston pin came out and scored the cylinder wall. i was wondering if i should get a new block or get it bored out and if so should i get it sleeved?
Old May 19, 2008 | 10:49 PM
00-501itrspec's Avatar
Default Re: block question? (96733)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96733 &raquo;</TD></TR><TR><TD CLASS="quote">got a type-r block that has excessive blow by. apparently the piston pin came out and scored the cylinder wall. i was wondering if i should get a new block or get it bored out and if so should i get it sleeved?
Bore it out by sleeving
OR
You can buy my extra ITR block , that already has 2 sleeves , it just needs 2 more and its a perfect 2.0 ITR block Pm me bout that one
But , original question ,
Sleeve it 84MM
Old May 20, 2008 | 09:32 AM
CW-ITR's Avatar
With the piston pin came loosed, I'll be very supprise if the set up is original from factory. The block probaly has been worked on befor the pin came loose. Anyway, the block probably need to be sleeve. If you have the budget, go for 84mm just as "00-501itrspec" said.
ringminion_blank
Aug 3, 2008 03:28 PM
IMPORTant Si
Oct 28, 2004 01:44 PM
dunkd
Aug 31, 2004 09:00 AM
slug
Jan 21, 2004 10:29 AM
