No first third or 5ht gear
Old Aug 9, 2006 | 01:35 PM
pgmatt's Avatar
Default No first third or 5ht gear
So i assembled my tranny a LS cable for my CRX project and put new diff bearings and a LSD in it.Assembly went fine it is pretty straightforward if your not doing any syncros etc and i have done a couple.I tested it on the bench seamed to shift through the gears fine so i installed it with the engine a couple weeks later.Now that it is in the car i was cutting and welding the Teg linkage to fit and found I could only shift into 2,4th and reverse.I thought at first i had cut the linkage to short but upon unhhoking it and trying to shift the tranny by hand found this problem.Anybody have any insight as to what has happened?I'm assuming something in the change holder has popped loose or similar.It shifts really nice through second,fourth and reverse it is crisp and solid feeling just no 1,3 or 5 gear Im about to pull it back but this sucks as a 6 month project was just about finished and i just got my new ign coil in today to fire it up and break the new engine in
Old Aug 9, 2006 | 02:02 PM
Bense's Avatar
Default Re: No first third or 5ht gear (pgmatt)
It's something in the shift rod mechanism, time to pull the tranny
happens to the best of us
Old Aug 9, 2006 | 02:11 PM
Danny_EJ's Avatar
make sure you have fluid mine was hard to shift dry
Old Aug 9, 2006 | 05:35 PM
pgmatt's Avatar
Default Re: (Danny_EJ)
Yes it has Honda MTF in it.Im going to drop it out tonight.Some days I wish i was into collecting stamps instead of building turbo Hondas
Quiks66
Jul 18, 2009 01:11 PM
B16aCRXSi
20
Nov 7, 2008 11:49 AM
nick lsvtec
Feb 17, 2008 05:04 AM
VegaS10
15
Dec 13, 2005 03:28 AM
akirab16
Oct 10, 2004 03:35 PM
