idling problem
Old Aug 3, 2006 | 10:29 AM
Tealeg88's Avatar
Default idling problem
hey I have a 98 dx hatch with a jdm b16a2. Anytime I start the car, the idling will go keep reving in between 1500-2500 rpms at consistant rate. I checked for any vacum hose leaks, and there doesn't seem to be any. There are no check engine lights. And after about 10 minutes it will stop and idle at a consistant rate of 500 rpm. Anyone have any ideas on what maybe the cause. Thanks.
Old Aug 3, 2006 | 11:10 AM
Eg_TypeR's Avatar
Default Re: idling problem (Tealeg88)
i had that problem..... maybe its the IACV
Old Aug 3, 2006 | 06:44 PM
Tealeg88's Avatar
Default Re: idling problem (Eg_TypeR)
would it help to clean out it out with some car cleaner?
Old Aug 3, 2006 | 06:45 PM
Tealeg88's Avatar
Would it help to clean it out with some carb cleaner?
Old Aug 3, 2006 | 07:02 PM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tealeg88 &raquo;</TD></TR><TR><TD CLASS="quote">Would it help to clean it out with some carb cleaner?
I assume if the metal mesh filter is dirty on it yes... or if maybe there are large debris in it that would cause it to peform poorly. Unbolt it during the day and take a flashlight and look at it and see if it's dirty. If it's not then I'd say put it back on and look else where... if it is, then go ahead and remove the coolant lines and then clean it with carb or brake cleaner.
I pulled mine today and it was very clean.. i guess thanks to my AEM intake... keeps the air charge clean.
silverlude80
Aug 2, 2011 07:43 PM
SOHC_civic_si
Sep 24, 2008 05:26 PM
bigandy90
Dec 11, 2007 05:44 AM
joboost13
11
Jul 27, 2007 06:46 AM
TypeRPaul
May 21, 2004 05:43 PM
