missfire getting worse
Old Aug 2, 2006 | 01:53 PM
DC5ftmfw's Avatar
Default missfire getting worse
My cars been missing at idle for a while now and I haven't paid much attention to it but now it's really starting to do it pretty bad. For instance, when I crank it after it's sat all night, it's rev's up and misses and sounds like it's on the rev limiter or something for just a split second and then goes down and idles fine but still slightly misses. It's also starting to miss around 7k as well. So I decided to try and figure out the problem. I did a compression chest and it got 220psi across the board. The plugs are new NGK's and the plug wires are new NGK's. I also replaced the rotor button as well. Still misses...The only thing I can think of would be the ignitor or the coil. Which is more common to be bad with these symptoms?
Old Aug 2, 2006 | 05:09 PM
slowcivic2k's Avatar
Default Re: missfire getting worse (jspec *****)
both get tired and old after about 110,000 miles, but the coil is the bigger of the two problems, pull it out and check its winding resistance.
Old Aug 3, 2006 | 06:05 AM
DC5ftmfw's Avatar
Default Re: missfire getting worse (slowcivic2k)
Thanks man. I'll do that. My #1 guess was that it would be the coil and my 2nd guess would be the ignitor.
Old Aug 4, 2006 | 10:06 PM
DC5ftmfw's Avatar
Default Re: missfire getting worse (StevesEKhatch)
Man I was out playing around tonight and that miss is realllly becoming noticable around 7k and 7.5k sometimes now. Does that sound like the coil or what? I need someone with some experience with this stuff.
Old Aug 7, 2006 | 05:43 AM
DC5ftmfw's Avatar
it was the coil going bad. Got a new one and now it runs great.
Brandon Irwin
May 11, 2012 04:28 AM
LST2
Jul 28, 2008 06:05 PM
bennyDA
Nov 9, 2006 04:28 AM
delslow94
Nov 30, 2003 11:24 AM
dvp95
Aug 20, 2003 11:10 AM
