The R keeps fouling o2 sensors, or at least throwing codes. ODB1, Hondata, JRSC
Old Aug 2, 2006 | 07:53 AM
MOVE OVER's Avatar
Default The R keeps fouling o2 sensors, or at least throwing codes. ODB1, Hondata, JRSC
I am curious to find out why the car keeps throwing a code for the primary o2 sensor. The primary was replaced back in September when I bought the car, and then a week ago I swapped the primary and secondary sensor because OBD1 does not use the secondary.
Every now and then (twice a week??) I get code 1 which is the primary sensor. It is a soft code and goes away if i turn the car off.
Is it possible that the ecu is bad? Or what other possibilities am I looking at?
JRSC 7 psi, Hondata S200, Kenji harness, RC 440 cc injectors, Hondata IM gasket, AEM cold air, stock exhaust manifold, gutted cat, apexi world sport 2 exhaust, Walbro hi flow pump.
Old Aug 2, 2006 | 08:51 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: The R keeps fouling o2 sensors, or at least throwing codes. ODB1, Hondata, JRSC (ITR 1102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1102 &raquo;</TD></TR><TR><TD CLASS="quote">I am curious to find out why the car keeps throwing a code for the primary o2 sensor. The primary was replaced back in September when I bought the car, and then a week ago I swapped the primary and secondary sensor because OBD1 does not use the secondary.
JRSC 7 psi, Hondata S200, Kenji harness, RC 440 cc injectors, Hondata IM gasket, AEM cold air, stock exhaust manifold, gutted cat, apexi world sport 2 exhaust, Walbro hi flow pump.</TD></TR></TABLE>
Well swap them back. Maybe you had a faulty secondary...
Old Aug 2, 2006 | 09:09 AM
nholmes's Avatar
My secondary has been throwing a code for a while now.
I just ignore it, I don't think the Hondata cares really.
Old Aug 2, 2006 | 05:04 PM
MOVE OVER's Avatar
Default Re: The R keeps fouling o2 sensors, or at least throwing codes. ODB1, Hondata, JRSC (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Well swap them back. Maybe you had a faulty secondary...</TD></TR></TABLE>
I have never thrown a secondary o2 sensor code before, only the primary. That is why I find it very unlikely that the o2 is bad. Like I said, I replaced the primary only a couple thousand miles ago with a brand new oem one, before swapping my primary and secondary... But the primary sensor is bad, so there is no point in swapping them back now.
I basically want to know if anyone has heard of a bad ecu causing codes to be thrown when there is not really an issue (i.e. primary sensor) I have a p28 ecu
turbo95eg6
Jul 2, 2005 08:27 PM
mraudio13
Apr 10, 2004 04:57 AM
gsrvx
Dec 18, 2003 05:43 PM
94jaxgsr
Sep 4, 2003 09:06 AM
