sohc vtec
Old Aug 1, 2006 | 01:11 PM
95civicz6ex's Avatar
Default sohc vtec
i have a 95 civic dx and put a d16z6 in it and the check engine light is coming on i had it check and its coming up Variable Valve Timing and Valve Lift Solenoid and Variable Valve Timing and control pressure switch. does anyone have any idea what would cause it? do you have hard wire the vtec in on the dx's? someone plz help!!!
Old Aug 1, 2006 | 01:14 PM
Syndacate's Avatar
Default Re: sohc vtec (95civicz6ex)
Umm..did you wire up the vtec at all?
There's no vtec to begin with...so uhh...what'd u do wiring wise?
Old Aug 1, 2006 | 01:21 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicz6ex &raquo;</TD></TR><TR><TD CLASS="quote"> do you have hard wire the vtec in on the dx's? someone plz help!!!</TD></TR></TABLE>
yes
Old Aug 1, 2006 | 01:32 PM
dxsohcvtec95's Avatar
Default Re: sohc vtec (fast95eg8)
a yow wat u could do is go over ur wiring n make sure that u connected every thing correctly. if u not sure get someone with the same engine that u have n look at how the engine is wired
Old Aug 1, 2006 | 02:23 PM
Jonknee's Avatar
Default Re: sohc vtec (dxsohcvtec95)
Check your wires with a multimeter.
Old Aug 1, 2006 | 02:30 PM
Das Bar 2k4's Avatar
Default Re: sohc vtec (Capn'jazz)
u need to run wires from the vtec solenoid to the pinouts on the ecu plug bc the 94-95 civics didn't come pre-wired for vtec. It's going to be 2 wires form the solenoid to ecu and another to a ground. good luck
Old Aug 1, 2006 | 02:42 PM
Jokerluv's Avatar
Default Re: sohc vtec (Das Bar 2k4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Bar 2k4 &raquo;</TD></TR><TR><TD CLASS="quote">u need to run wires from the vtec solenoid to the pinouts on the ecu plug bc the 94-95 civics didn't come pre-wired for vtec. It's going to be 2 wires form the solenoid to ecu and another to a ground. good luck </TD></TR></TABLE>
92-95 Si & VX have vtec
Old Aug 1, 2006 | 03:04 PM
whiteej1's Avatar
the 95 dx dont come wit vtec
but the 95 ex (d16z6) do
i think that it is an ecu issue
i just say go with the 95 ex ecu (p28)
Old Aug 1, 2006 | 05:10 PM
BauleyCivic's Avatar
Risky Business
Default Re: sohc vtec (whiteej1)
https://honda-tech.com/zerothread?id=1171263
swizz977
10
May 25, 2011 08:15 PM
nutball72
May 6, 2006 05:05 PM
92hatch420
10
Jan 22, 2006 08:15 AM
SpoonEk253
21
Nov 20, 2005 04:11 PM
AdamQ3B85
27
Jul 22, 2003 03:08 PM
