b20vtec, VTEC not workin?!!?
hey you guys i've swapped in a b20vtec into my 96hatch n i get a check engine light for code 21 vtec solenoid! do i still gotta wire up the solenoid,pressure switch, and a ground? even though im using a 98ex because ex comes w/ vtec already? any info would be greatly aprreciated!
Modified by SpoonEk253 at 10:46 AM 11/19/2005
Re: b20vtec, VTEC not workin?!!? (SpoonEk253)
Did you wire in vtec? Haha..it just is funny to me! There are three wires for it i believe!
Dutch
Dutch
Re: b20vtec, VTEC not workin?!!? (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT »</TD></TR><TR><TD CLASS="quote">Did you wire in vtec? Haha..it just is funny to me! There are three wires for it i believe!
Dutch</TD></TR></TABLE>
Thats what i was thinkin, and yes one for solenoid, one for pressure switch, and another for ground i dont know what pins offhand
can I haz?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonEk253 »</TD></TR><TR><TD CLASS="quote">hey you guys i've swapped in a b20vtec into my 96hatch n i get a check engine light for code 21 vtec solenoid! How do i get this to go away....is there any wiring i was suppose to do prier to installing a vtec head on a b20? any info would be greatly aprreciated!</TD></TR></TABLE> check the voltage with a meter on your soleniod maybe its busted.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonEk253 »</TD></TR><TR><TD CLASS="quote">is there any wiring i was suppose to do prier to installing a vtec head on a b20? any info would be greatly aprreciated!</TD></TR></TABLE>
Are you serious? Did you think you could just put it on and it would magically activate on its lonesome - like some little gnome was going to pop out of the solenoid with a golden hammer and start banging more horsepower into your engine?
Yes you have to wire it up! Who knows how to do this mechanically but lacks the foresight to research it?
Re: b20vtec, VTEC not workin?!!? (thid92)
Yes, you need 3 additional wires for the two vtec components, a 4th if using a stock p30 or p72 ecu with knock sensor board.
Otherwise check the ground you used for the wire - mine was half-assed, and didn't work till I exteneded it to the battery, and later (cleanly) to the thermostat housing ground.
Re: b20vtec, VTEC not workin?!!? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Yes you have to wire it up! Who knows how to do this mechanically but lacks the foresight to research it?</TD></TR></TABLE>
ok first of all i wasnt askin for a smart *** remark.....just askin a simple question w/ a answer explaining to me how to do so!
https://honda-tech.com/zerothread?id=1269147
Hope that helps...
Kinda hard to resist being a smart *** when you slap a Vtec head on and expect the Vtec fairy to come out at 5200 rpm and begin unleashing the mAd TytE VeTEcH poWA!
Hope that Helps...if you need more help...SEARCH...I typed Vtec Wiring and got alot of stuff!
Dutch
Hope that helps...
Dutch
but shouldnt the engine harness im using already be wired for vtec? its a 98ex harness in a 96 dx hatch....ex come w/ vtec?the only thing i can think is that i gotta run some wires to the ecu...anyone know anything about wiring for a obd2 ecu...
Good God Jesus Christ!!!!!!
YOU MUST WIRE UP VTEC!
Your chassis is a DX! DX DID NOT COME WITH VTEC!!
Even if you use a EX wiring harness, you still have to wire it up!
The only hatches that came wired up for VTEC is all 92 hatches and all Si model hatches.
If you want help, then don't be a f*cking jackass. Jackass!
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">
If you want help, then don't be a f*cking jackass. Jackass!</TD></TR></TABLE>
oof, jeeze, i know h-t has tought me a couple of things
lets just give the kid a break here...after all, this is your honda/acura technical resource.
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">Good God Jesus Christ!!!!!!
ok kid...it was only a question that i need to know, no need for faul language here! haha this guy its all work up over nothing.... kids these days! lol
Re: (SpoonEk253)
Well brotha...you aint really helping yourself out! We have done everything but come to your house and wire it up for you!
Dutch
Dutch
hmmmm, i cant front i was thinking the same thing. I thought the purpose of getting a ex, si, gsr harness was so it was all plug and play and that you didnt have to add any wires to it.
Im doing a b20vtec with a p72 head and p28 ecu into a 94 EH. i thought that if i got the gsr wiring harness that it was all plug and play??
Re: (MI4EH2)
You still need to run wires from the shock tower to the ecu! Or if you're using a dx.vx..blah blah blah..you have to make a complete harness!
Research people!
Research people!
civictype-r
20
05-17-2006 03:36 PM
