itr cams into a b16
Old Aug 1, 2006 | 12:50 PM
Slow_import's Avatar
Default itr cams into a b16
hey guys, i've tried searching but couldnt find anything so i thought i'd ask, if i was to put itr cams in my b16, is there any valve adjustments needed, and would there be any valvtrain problems in the long run if i dont up grade to itr valvtrain....
Old Aug 1, 2006 | 12:55 PM
philosofy1's Avatar
Default Re: itr cams into a b16 (Slow_import)
not really, since it is an upgrade, it is not a drastic of an upgrade. IMO, if your planning on putting them in you might as well do a valve adjustment. kill 2 bird with 1 stone.
Old Aug 1, 2006 | 01:00 PM
SkoundrelUSA's Avatar
cute little bastard
just throw them in and keep it under 8k and you should be good
Old Aug 1, 2006 | 01:02 PM
Default Re: itr cams into a b16 (SkoundrelUSA)
well the thing is i heard that if i dont do the valve adjustments at certain rpms you hear a slight knock....but i dont know if its true, and i just wanted to know if the valve adjustment is very neccessary if i plan on reving to 8 grand only....
Old Aug 1, 2006 | 01:06 PM
philosofy1's Avatar
regardless if you have the cams or not, when a adjustment is needed they will tap. that's how all hondas are and should be part of your routine maintence. but you can stll take it to 8000.
Old Aug 1, 2006 | 01:08 PM
egsleepercivic's Avatar
any time you install cams you want adjust valve lash
Old Aug 1, 2006 | 01:11 PM
FalkenSiR's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">any time you install cams you want adjust valve lash </TD></TR></TABLE>
exactly.
Old Aug 1, 2006 | 02:33 PM
Das Bar 2k4's Avatar
Default Re: (fast95eg8)
what year itr cams r u using j/w 96spec or 98 spec or usdm itr cams
Old Aug 1, 2006 | 07:47 PM
Default Re: (Das Bar 2k4)
usdm itr cams...not quite sure....
Old Aug 1, 2006 | 08:21 PM
Sleepy_Red_hatch's Avatar
Default Re: (Slow_import)
my god, your acting as if valve adjusting is a hard and grossly long process, its pretty easy to do, theres even a few write ups on it.
Old Nov 16, 2006 | 04:00 PM
WHAT TEH's Avatar
i know tha IT-R's titanium springs & retainers are recommended, but are they absolutely required? will i be able to run tha IT-R cams safely w/o them?
_taF
b20vtecturboeg9
Oct 22, 2009 03:23 AM
EK Dave
13
Jul 25, 2007 11:43 AM
Slow_import
Aug 1, 2006 03:54 PM
StinkyTofu
May 25, 2003 05:16 AM
