itr cams on b20vtec turbo
i have a stock b20 motor b16 head blox manifold n block guard t3/t4 turbo on 9psi. my friend is selling some itr cams n gears for $200 will it make a power difference n is it worth it..
i hear it wont n i hear it will aaawhhgrrrr
Re: itr cams on b20vtec turbo
ITR cams have more aggresive lobes than the B16 cams there for you should gain some power, but i would recomend that you get some dual springs for example ITRs, Blox, Skunk 2 ect. and also tune your car if youre gonna do this the results will be much greater.............
i would upgrade to itr valve train with itr cams since b16 are single spring on both side
or even get supertech valve spring with rsx type s retainers($45 brand new) if you want to upgrade your valve train
InfamousRS
06-16-2002 09:18 PM
