HOW TO ADJUST THE CLUTCH????
whats going on ht someone told me you can adjust ur clutch alot lower because mine catches wayyyyy too high it i was thinkin either my clutch is gone or i really could just ajdust it lmk
if you have a cable clutch you can adjust it, just tighten the cable where on that bracket near the clutch fork. if its a hydro, you can only bleed it. but most of the time, your clutch is not grabbing because its warn out and you need a new one
If it's a cable clutch you want to loosen the cable. Besides, you didn't say whether it's a hydraulic clutch...
But since it slips when you shift, that probably means your clutch is shot.
danno33
12
Sep 30, 2012 08:46 PM
I8ayellowcrayon
Aug 23, 2004 07:18 PM
