Low dipping Idle!!!!! I've searched!
Old Jul 27, 2006 | 04:41 PM
Fighterinsnatch's Avatar
Default Low dipping Idle!!!!! I've searched!
Ok I can't fix my idle. I have tried backing out the idle adjustment screw all the way and it does not help. I opened up the radiator cap and it looked full but when I went to check to see if it was low or high, it was completely empty, that did'nt really make any sense. Can anyone please tell me what I could try to fix this. Right now it idles at like 500rpm and if I turn on the A/c then it just stalls out. Any help would be great. Thanks
Old Jul 27, 2006 | 05:08 PM
B16CivicEX's Avatar
mine did same thing, A/C was over charged, friends car did the same thing, he had bad expantion valve in the a/c under passanger side dash, was causing the compresser to work to hard, and stalling the car...
im in P/C too if you need help. Are you AF?
Old Jul 28, 2006 | 01:55 PM
Bump. I still have not figured out what could be wrong.
Old Jul 28, 2006 | 02:06 PM
philosofy1's Avatar
Default Re: Low dipping Idle!!!!! I've searched! (Fighterinsnatch)
a year ago i had the same problem, changed my pcv valve and problem solved. $3 didn't hurt my wallet.
the one thing people seem to forget is the pcv valve. although it is little and seems worthless, when bad it can cause this. it is only like $3, go buy one, replace it and then see what happens. takes like 5 minutes to replace. if that's not the case it might be your idle control valve, which also does this.
James648405
Jan 14, 2010 09:13 AM
crawlin
Sep 4, 2006 04:09 PM
jaydoghondacivic25
Jan 30, 2006 09:01 PM
slp mode
Dec 21, 2003 08:11 AM
