odomoter - searched
Old Jul 27, 2006 | 04:34 PM
alacard's Avatar
Default odomoter - searched
i know it has been covered before...but i cant seem to find anything 96-00 civic specific...i just got a used cluster than im going to swap into my 98 dx...i just want to match the mileage to be correct (not trying to roll it back so i can sell it with less miles).. like i said i searched and couldnt find anything specific to my car...any help would be appreciated...pm me if you dont really want to let the world wide web know how to roll back their mileage.
thanks in advance
Old Jul 27, 2006 | 05:04 PM
BlueIntegraBoy's Avatar
Default Re: odomoter - searched (alacard)
Behind the speedometer, there are 4 screws. Remove them to remove the gauge from the housing. Swap it over to the new cluster.
Old Jul 27, 2006 | 05:11 PM
alacard's Avatar
Default Re: odomoter - searched (BlueIntegraBoy)
does this remove the speedometer too?...or just the odometer mechanism?
Old Jul 27, 2006 | 05:15 PM
It removes the whole speedometer/odometer portion. So, if you bought an EX cluster with a tach, just swap over that portion to retain your mileage.
Old Jul 27, 2006 | 09:50 PM
alacard's Avatar
bleh...it wouldnt match..how would i change the mileage...because the cluster i got is in kilometers so i would have to convert my mileage to kilometers and then change it.
Old Jul 27, 2006 | 09:57 PM
No you don't. Your old cluster is MPH? Swap the speedo/odo in, and it will still read in MPH.
Old Jul 28, 2006 | 09:17 AM
alacard's Avatar
no no...i dont want to swap the speedometer/odometer's... it wouldnt match on the new one....and i want to keep the kilometers...just because its different...but thanks for the help....can anyone tell me how to change the odometer?
Old Jul 28, 2006 | 09:21 AM
EL Vap133's Avatar
Just leave it how it is then if the new speedo is in KMH.
Old Jul 28, 2006 | 09:24 AM
prison_snitch's Avatar
just write it down on a peice of paper
Old Jul 28, 2006 | 09:25 AM
I supposed you bought an SiR cluster. Anyways, get like a sticker or something. Write down the mileages of both clusters. When you sell your car, figure out the difference in mileage on the KMH odo, convert it, and add it to the MPH odo. This is what I am doing right now. Oh, the sticker goes in the glove box.
Old Jul 28, 2006 | 10:20 AM
alacard's Avatar
ah...yeah, that is something i can do...i just really wanted it matched. thanks
Old Jul 29, 2006 | 11:57 PM
redrocket's Avatar
can the odo be read off the ecu somehow? or is that only on the 2001+ ?
Old Jul 30, 2006 | 11:13 AM
alacard's Avatar
Default Re: (redrocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrocket &raquo;</TD></TR><TR><TD CLASS="quote">can the odo be read off the ecu somehow? or is that only on the 2001+ ?</TD></TR></TABLE>
not stock ecu anyway...haha...but thanks.
please someone pm me with a way to change mileage/kilometerage on my cluster so i can put it in
Old Jul 30, 2006 | 03:16 PM
Default Re: (alacard)
https://honda-tech.com/zerothread?id=837111
Old Jul 30, 2006 | 04:50 PM
alacard's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=837111</TD></TR></TABLE>
i searched and found that...but im not sure how different it would be with a civic cluster
Old Jul 30, 2006 | 07:36 PM
redrocket's Avatar
i rolled mine (eg) back a bit today, just for giggles (i'm never selling it, so it wasnt for that reason). What i did was pull the speed/odo out of the cluster, removed the circuit board, then removed the stepper motor that drives the odo. Then - the fun part - i ran a dremel wheel against the main odo gear (not the trip odo) and ran the digits backwards.
Another thing you could try, if you have the skills, and dont want to risk breaking your gauge, is wire it up to roll forward at a very fast speed. You need 3 wires for this: +12v, Ground, and a +5v VSS pulse (could use a serial, parallel, or usb cable with some homebrew hack code to generate the VSS). It takes about 17 pulses per sec to simulate 60mph, so you could probably pulse the hell out of it on a PC & roll it to your desired km-age in no time. Since you are converting Mi to Km, you'll want to roll forwards anyway.
whatever all that's worth
Old Jul 30, 2006 | 10:50 PM
alacard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrocket &raquo;</TD></TR><TR><TD CLASS="quote">i rolled mine (eg) back a bit today, just for giggles (i'm never selling it, so it wasnt for that reason). What i did was pull the speed/odo out of the cluster, removed the circuit board, then removed the stepper motor that drives the odo. Then - the fun part - i ran a dremel wheel against the main odo gear (not the trip odo) and ran the digits backwards.
whatever all that's worth</TD></TR></TABLE>
thanks for the info...i guess ill just take it apart and see what i can do.
NOFX
30
Dec 22, 2014 04:42 PM
hotcivicsi
May 4, 2009 02:53 PM
DxBurnoutKing
Jun 27, 2007 03:56 PM
mugenpowered
12
Apr 29, 2006 02:01 PM
tRex99
Nov 11, 2004 01:46 PM
