00'Si , new dizzy,now tach wont work....
Old Jul 27, 2006 | 04:24 PM
m00nr0ck Si's Avatar
Default 00'Si , new dizzy,now tach wont work....
my brother just put a new distributor in his 00' si and now the tach is dead....any ideas? it is a jdm b16a w/ a obd 2 to obd 1 harness....running the jdm obd1 ecu...
Old Jul 27, 2006 | 05:18 PM
JDMlyfestyle's Avatar
ive bought brand new distributors before and they were already bad. Id try another distributor.
Old Jul 27, 2006 | 05:42 PM
Default Re: (JDMlyfestyle)
well the car runs great....the tach just does not work....I think the engine harness is from a B16A and the harness from the ecu is from the 00 si... and then its got a obd1 conversion harness ...so Im thinking that the dizzy might have been from an obd1 b16A and the one he got to replace it is from a 00si.....holy crap thats alot of mismatching....
BTW is the 00si dizzy 1 plug and is the b16A 2 plug?
Old Jul 27, 2006 | 06:06 PM
Default Re: (dorkoftheyear)
you cannot plug in a OBDI dizzy into a OBDII plug. or vise versa
Most likely his tach wire came loose or that part of the ICM has gone bad.
if its a brand new dizzy from a parts store.. take it back because its not working 100% so its defective and they got to replace it
Old Jul 27, 2006 | 06:19 PM
okay its a obd2 2000 Si harness,2000 si dizzy......I just found that out by searching
amazing....
is there any wires that have to be moved on the dizzy plugs when using the obd1 conversion harness with a jdm b16a ecu....?
Maybe the bastard is bad....
Old Jul 27, 2006 | 06:27 PM
b18ccivics's Avatar
on a 2000 si your tach signal comes from the ecu, not the dizzy like on 98 and older cars. If you use a conversion harness the signal comes from pin a21 when you use an 0bd1 ecu.
Old Jul 27, 2006 | 06:40 PM
Default Re: (b18ccivics)
its has to get its signal from the dizzy at some point....Im going with jdmlifestyle on this one.....its got to be bad.....Im pretty sure its a rebuilt dizzy from napa ...
thanx for the replys though...
Old Jul 27, 2006 | 06:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">on a 2000 si your tach signal comes from the ecu, not the dizzy like on 98 and older cars. If you use a conversion harness the signal comes from pin a21 when you use an 0bd1 ecu.</TD></TR></TABLE>
sorry but the signal gets sent to the ECU from the ICM the same way it did in all 88-00 Fuel Injected Honda's B D H F series motors
Old Jul 31, 2006 | 02:51 PM
b18ccivics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">
sorry but the signal gets sent to the ECU from the ICM the same way it did in all 88-00 Fuel Injected Honda's B D H F series motors</TD></TR></TABLE>
you are wrong sir, look at a 99-00 si ex and hf (i have worked on them all) the dizzy has a blue wire coming out of it, but there is no wire in the harness for it to hook to.
and on 92-95 civics the blue tach wire doesnt even hook to the ecu.
dont post if you dont know.
Old Dec 21, 2006 | 02:02 PM
wtfitzsoda's Avatar
up for reference
Effin-Jay
16
Apr 2, 2014 07:27 AM
Muckman
Jul 3, 2013 10:20 AM
SKAVENGER88
Jul 20, 2012 07:24 PM
ramco
Jan 8, 2012 05:13 PM
uvamosk
Engine Management and Tuning
Jul 7, 2011 12:08 AM
