94 accord DX swap to Vtec HELP!
Old Jul 27, 2006 | 02:29 PM
jjyynnxx's Avatar
Default 94 accord DX swap to Vtec HELP!
ok i got a 94 DX and i'm swapping a sohc vtec engine in...my mechanic says that he won't be able to make the vtec work because the wire harnesses aren't the same, is this true? i mean isn't there a way for me to make the vtec work? please help, thanks in advance
Old Jul 27, 2006 | 02:57 PM
YeuEmMaiMai's Avatar
Default Re: 94 accord DX swap to Vtec HELP! (jjyynnxx)
he is right. You will need to run a wire for Vtec solenoid and will also need a Vtec ECU. Engine will bolt up and run just fine in your car......with or without vtec
Old Jul 28, 2006 | 06:11 AM
MaXiMuS1701's Avatar
Default Re: 94 accord DX swap to Vtec HELP! (Mr Wonderfull)
i just did this swap this weekend and know what you will have to do.
first you do not have to replace your wire harness you just have to run 2 wires through your firewall to the vtec solenoid, one for the spool and one for the oil pressure sensor. the 3rd wire is just a ground that can be grounded anywhere in the engine compartment. the engine will bolt up perfectly and run off of your current ECU but the Vtec will not run you will need to buy a P0A ecu, from ebay or where ever, and then just plug the vtec spool into A4 and the oil pressure sensor in to D6 of the new ECU. any other questions feel free to ask. Mine runs great and have had no problems so far.
Old Aug 10, 2006 | 05:42 AM
jjyynnxx's Avatar
ok thanks for all your help, yea my mechanic is a retard, and i'm pissed that he's been tryin to jerk me like this, anywho so while in the process of getting mad at his him, i also managed to get the orginial ECU from the vtec engine, so that should be able to work correct? sorry i'm new hooking up a honda, but thanks again for your help
Old Aug 10, 2006 | 06:23 AM
TheMuffinMan's Avatar
He knows where you live!
Yeah if you've got the original ecu from the f22b1 you should be good to go
Old Aug 10, 2006 | 09:06 AM
jjyynnxx's Avatar
great! hopefully i can find someone to do this, cause i really don't want to mess with anything electrical
Jackwj5
Jan 21, 2017 05:35 PM
swizz977
10
May 25, 2011 08:15 PM
DJcaseychaos
Apr 16, 2004 09:49 PM
Azntwins
Mar 8, 2004 12:08 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
