my vtec isnt working
Old Jul 27, 2006 | 08:58 AM
breanna*'s Avatar
Default my vtec isnt working
delete
Old Jul 27, 2006 | 09:06 AM
G2 Speed's Avatar
Default Re: my vtec isnt working (breanna*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breanna* &raquo;</TD></TR><TR><TD CLASS="quote">so my car is extremly messed up and theres sooo much wrong
i recently got a jumper and a p28 and my vtec still isnt cracking.
my cel is on becasue of a few censors i need but i dont believe that can effect my vtec.
hmmmmm and also my cel randomly goes off and then 10 secs later it comes back on
hmmm
help?</TD></TR></TABLE>
ummm lol.. maybe you should replace those sensors...
and yes they can affect VTEC
Old Jul 27, 2006 | 09:18 AM
Brick Top's Avatar
ya, wrong assumption. they will affect vtec. what are the codes?
Old Jul 27, 2006 | 12:57 PM
allmotor89hf's Avatar
put oil in it.
Old Jul 27, 2006 | 01:00 PM
tatmark1's Avatar
fix your problem then maybe youll get it "crackin"
Old Jul 27, 2006 | 02:30 PM
Slopoke's Avatar
Default Re: (tatmark1)
Yeah, pull the codes and see what they are.
Fix those first and odds are, when your done, your vtec will be working.
Old Jul 27, 2006 | 03:08 PM
JDMlyfestyle's Avatar
Default Re: (Slopoke)
In order to engage in vtec you need the following requirements from your car
55 psi of Oil pressure
Set RPM's for Vtec to Engage
Water Temperature must be at 140* to engage in vtec
Vehicle must be going faster than 10 mph.
Engine sensors that are not working could effect Vtec.
Also if you lack oil pressure then vtec wont engage. Is your car eating alot of oil?
Old Jul 27, 2006 | 05:16 PM
Jonknee's Avatar
Default Re: (JDMlyfestyle)
Tps sensor has to be in working condition * i learned the hard way*
Old Jul 27, 2006 | 09:13 PM
d16vteceg's Avatar
Default Re: (Capn'jazz)
make sure you don't have a major leak in your vtec solenoid. Like previously mentioned if you don't have enough oil pressure your vtec won't work. There are two gaskets in your solenoid, one connected to the head which at honda is like 25 bucks, and one in between the top and bottom pieces of the "assembly" that is like 6 or 7.
Old Jul 27, 2006 | 09:14 PM
d16vteceg's Avatar
Default Re: (B18chatch83)
ALSO REPLACE OR PUT IN ALL OF YOUR SENSORS!!!
Old Jul 28, 2006 | 02:14 AM
breanna*'s Avatar
my tps and i believe the censor on the back of the intake manifold..the bottom. yeah i thought maybe cuz of my tps but ppl were telling me it diff. so yeah ill change them tomorrow and see...
thanks everyone
&lt;3
bre
HKM
Old Jul 28, 2006 | 02:22 AM
Default Re: (breanna*)
Doesnt mean your sensor is bad. It needs to be calibrated to ensure that its reading properly...
If your TPS sensor went out you would know it.. Cause if u went to WOT the car wouldnt even rev up hardly at all.
Old Aug 2, 2006 | 09:29 AM
breanna*'s Avatar
yeah well my car rl at 6 and it jumps and barely wants to start sumtimes
b16mike
May 13, 2005 09:51 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
acdracing
Dec 13, 2004 06:13 PM
lmiguelvv
Oct 19, 2004 06:55 PM
97dc2
Sep 23, 2004 12:00 AM
