Rich Running B16 Swap Please Help!
Old Jul 24, 2006 | 07:27 PM
wsriane's Avatar
Default Rich Running B16 Swap Please Help!
Noob here in desperate need of some tech assistance. A little background, I am a Ford Tech of 5 years and I used to work on Hondas back in the day. Anyways I got a 90 Dx Civic hatch with a jdm b16 that i swapped in. The ecu is a pr3, I have an jdm si injector resistor box. My problem is that when it idles it is just dumping fuel. Its running way too rich and if it persists it will eventually wash the motor out. It has no codes, I am using the 1.5 o2 sensor and one of the jdm o2 sensors that came on the engine. The fuel pressure is 29-32 psi at idle and the fuel return hose is not kinked. The fuel pressure regulator is new and is working properly. There are no vacuum leaks and for the life of me I cannot throw anymore parts at this car! If someone could share some knowledge I would be greatly appreciative and could share some ford info if needed(Diesel,Gasoline,LPG,CNG Technician. Please Help a Newb out. Thanks
Sincerely
Wes Srianekkul
w-sriane@hotmail.com
Old Jul 24, 2006 | 07:31 PM
onepoint6i's Avatar
Default Re: Rich Running B16 Swap Please Help! (wsriane)
you are sure the ecu is not chipped right? how does it run besides idle?
Old Jul 25, 2006 | 12:29 PM
wsriane's Avatar
Pretty sure the ecu is not chipped, although it i did buy it off ebay
Old Jul 25, 2006 | 01:28 PM
onepoint6i's Avatar
Default Re: (wsriane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wsriane &raquo;</TD></TR><TR><TD CLASS="quote">Pretty sure the ecu is not chipped, although it i did buy it off ebay</TD></TR></TABLE>
pop the cover and check it out..
you swapped the tps wires right?
Old Jul 25, 2006 | 02:49 PM
wsriane's Avatar
Default Re: (onepoint6i)
yes, green/white with yellow/white
Old Jul 25, 2006 | 02:57 PM
Magick211's Avatar
Maybe you have some sticking injectors, Maybe one is stuck open. Also your map sensor may be bad
Old Jul 26, 2006 | 06:33 AM
wsriane's Avatar
Default Re: (Magick211)
That I know of this motor doesn't have a map sensor. Hmmm. Pretty sure the injectors aren't sticking because it isn't a specific cylinder, they are all running rich, all plugs are fouled
Old Jul 26, 2006 | 07:08 AM
onepoint6i's Avatar
it does have a map sensor bro..its on your fire wall...did you route it to your intake manifold.
Old Jul 26, 2006 | 02:41 PM
wsriane's Avatar
ok then yes it has a map sensor and I guess it is working, I don't believe you have to change any of the wiring for the map correct? You don't by chance have a vacuum diagram handy do you.. Thanks again for all of you guys help
wes
Old Jul 28, 2006 | 02:46 PM
wsriane's Avatar
Anybody got a pic of the map sensor and location??? If the map was faulty or unplugged wouldn't it throw a cel???(check engine light)
Old Jul 28, 2006 | 02:51 PM
onepoint6i's Avatar
right on the fire wall right under the vin number...hose goes to the top TB nipple besides the red hose right there
the two plug harness going to it...the map is the lower one with 3 wires
Old Jul 28, 2006 | 03:34 PM
savoeun147's Avatar
check to see if your injectors seating right .
Old Jul 28, 2006 | 04:38 PM
savoeun147's Avatar
Old Jul 28, 2006 | 04:46 PM
crxpwr1's Avatar
Default Re: Rich Running B16 Swap Please Help! (savoeun147)
https://honda-tech.com/zerothread?id=404493&page=1 thats a vaccum diagram right there
Old Jul 28, 2006 | 04:48 PM
savoeun147's Avatar
check your wire harness and see if it is rubbing on any metal;;stay voltage;;
check your throttle cable and adjust.back probe your ecm fuel injection terminal
pulse width mod. if it stay on too long it probally a driver problem such as an ecm
or stray voltage. if stray voltage;;; eliminate circuit one by one .like hook up a
test light in series with the battery and pull out fuse one by one..
Old Jul 29, 2006 | 01:07 PM
wsriane's Avatar
Finally figured it out. I didn't have the vacuum line from the map to manifold vacuum I had it ran to the charcoal canister. Anyways. thank you to everyone that helped and to those who helped please feel free to email with any ford questions.
thanks again
wes
Old Jul 29, 2006 | 01:44 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wsriane &raquo;</TD></TR><TR><TD CLASS="quote">Finally figured it out. I didn't have the vacuum line from the map to manifold vacuum I had it ran to the charcoal canister. Anyways. thank you to everyone that helped and to those who helped please feel free to email with any ford questions.
thanks again
wes
glad to hear that
Old Jul 29, 2006 | 01:59 PM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you have some sticking injectors, Maybe one is stuck open. Also your map sensor may be bad</TD></TR></TABLE>
I knew it was probally Map related
redef90si
Sep 9, 2010 05:01 AM
MIsterE533
May 13, 2008 08:55 PM
97grnrs
Nov 6, 2006 06:42 PM
87sivtec
Dec 26, 2002 09:42 AM
tinkerbell
Jan 22, 2002 02:24 PM
