need help with a code please :)
Old Sep 8, 2010 | 09:23 AM
redef90si's Avatar
Default need help with a code please :)
4 solid flashes,3 quick flashes 7 total It's happening on my obdo 1990 integra and only on the freeway and only over the speed of 60-70 mph(110-120 kms) I have replaced the o2 sensor with a brand new ntk one,Any help is appreciated,thanks Matt
Old Sep 8, 2010 | 06:17 PM
oly284's Avatar
Default Re: need help with a code please :)
two thin; one check fuel pressure specs 35 to 37 psi at idle and see if the regulator diaphragm is not leaking;(you will see fuel were the vacuum hose goes), two connect a volt meter to the O2 it need to cycle from about .01 volt to .08 volts, you could have a broken fuel pressure regular making your O2 read rich or if all looks good possible bad ecu, know a bad ecu extremely doubtful Honda ecu are extremely good.
Old Sep 9, 2010 | 05:01 AM
redef90si's Avatar
thx a ton,another great person/help from North carolina!
EH3forlife
Apr 19, 2009 06:30 PM
nv707
Oct 7, 2007 06:11 PM
ripperbone
May 31, 2007 04:21 PM
bucky4444
Mar 23, 2006 01:00 PM
delSolLS
Aug 5, 2004 11:10 AM
