Effects of running boosted car without charge pipe???? (noob)
Old Jul 23, 2006 | 08:55 PM
dohcdelsol's Avatar
Default Effects of running boosted car without charge pipe???? (noob)
To say the least, i do not own a boosted car and ive been doing research on them but come to this question.
A friend of mine has just recently boosted his d16z6. All he did was put the manifold, turbo, and down pipe on. Then run the oil lines and boost controller. Correctly lined up the vaccum lines and got a IC and IC piping.
For now it has no fuel management or fuel upgrades until he gets to a tunner. In the mean time he needed to drive the car. So in order to stay out of boost range, he disconnected the Intercooler to the throttle body piping and put on a filter.
My question, what harm could this cause to the turbo or engine??? The car never saw and boost at all, but the turbo was smoking a while ago and i think it blew an oil seal.
Please, intellegent answers only. Nothing stupid. And i know it needs injectors and fuel management and a tune so please dont tell me that.
Old Jul 23, 2006 | 09:02 PM
Schister66's Avatar
Man U FTW
your car won't recognize the fact that the turbo is boosting so the wastegate won't ever open and the turbo will spool until it wants to stop......basically if you try to show off or boost for any reason, you might mess up your set up....
Old Jul 23, 2006 | 09:04 PM
sohc_turd's Avatar
Default Re: Effects of running boosted car without charge pipe???? (dohcdelsol)
I'm sure its possible to spin a turbo into dangerously high rpms.
Old Jul 23, 2006 | 09:20 PM
.kyle's Avatar
Default Re: Effects of running boosted car without charge pipe???? (sohc_turd)
ha its my car. . its all good though. . one side of my compressor had some loose bolts (not crazy loose but i guess enough) and a smidge of oil was leaking. . it would then burn off and create smoke. . its mellow now. . no worries. .
Old Jul 23, 2006 | 09:34 PM
EK k kay's Avatar
Default Re: Effects of running boosted car without charge pipe???? (IWantATurbo)
Yes you can overspin the turbo.
Old Jul 23, 2006 | 10:20 PM
rebo0t's Avatar
yup.. you can overspin the turbo and damge the bearings. just pull the wastegate spring instead.
Old Jul 24, 2006 | 05:08 AM
SPOOLINmatt's Avatar
Default Re: (rebo0t)
what, i think you guys are wrong. My charge pipe blew off one time and i was playing with the sound it was making cause i was on the highway, really loud whine. I couldnt get it to do ****, WOT at like 7,000 rpm the turbo was just spinning at the same rate. because the turbo isnt producing any boost which just ends up coming out the exhaust and creating the big circle. People blow their couplers all the time at the track and keep on ragging for a sec, i know i have before, the turbo just slows the expletive down.
Old Jul 24, 2006 | 05:42 AM
notoriousB's Avatar
Default Re: (SPOOLINmatt)
you won't overspin the turbo. the motor's not seeing any boost so you won't put enough load on the turbo to overspin it.
Old Jul 24, 2006 | 05:44 AM
92HB_HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">what, i think you guys are wrong. My charge pipe blew off one time and i was playing with the sound it was making cause i was on the highway, really loud whine. I couldnt get it to do ****, WOT at like 7,000 rpm the turbo was just spinning at the same rate. because the turbo isnt producing any boost which just ends up coming out the exhaust and creating the big circle. People blow their couplers all the time at the track and keep on ragging for a sec, i know i have before, the turbo just slows the expletive down. </TD></TR></TABLE>
that's correct. .. To overspin the turbo, you'd have to cut your WG line since that's what regulates the pressures in the system..
Old Jul 24, 2006 | 08:34 AM
dohcdelsol's Avatar
Default Re: (92HB_HB)
so its actually perfectly ok then to run, temporary, without a charge pipe?? good to know when were on our way to the tunner.
Old Jul 24, 2006 | 09:11 AM
I Have an STD's Avatar
wrenchin'
Default Re: (dohcdelsol)
TUNER!! dammit learn to spell, i HATE when people spell it that way. just like when they spell CROME (the tuning software) CHROME. its drives me nuts.
:end rant:
Old Jul 24, 2006 | 09:19 AM
Default Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote"> TUNER!! dammit learn to spell, i HATE when people spell it that way. just like when they spell CROME (the tuning software) CHROME. its drives me nuts.
:end rant:</TD></TR></TABLE>
i spell it like that to **** you off.
Old Jul 24, 2006 | 09:29 AM
rsintegra's Avatar
Turbo is an air pump which simply pressurizes incoming air and then crams it into each cylinder...How do you build pressure without the pipes?
stevn
Jan 15, 2009 02:31 PM
johnsona
May 9, 2006 08:04 AM
chihuahuamanx
Feb 23, 2005 11:34 PM
It's*BOLO!!
Apr 22, 2003 07:27 PM
X2BOARD
May 31, 2002 07:53 AM
