Subwoofer bass on and off.. what could be the problem?
today i finally rewire the RCA cable and when i pulled the old one off, i accidently torn the tiny blue wire apart. so i reconnected everything and the bass stays when the car is not moving, but while im driving, the bass always come on and off. what could the problem be?
Well it's a good bet it's a loose connection, try turning on the system and then moving the wiring, [power, ground, amp control, RCAs and speaker leads] on the amp around a bit, tap hard on the amp itself.
The other thing I would check is the main power fuse, [by the batt.] if it is an "AGU" fuse holder, like this... http://www.scosche.com/efx.asp...P8FHI replace the fuse, even if it looks good, the AGU, [glass barrel fuse] the fuse filament can break or the fuse can get hot enough, [sub bass cranked] to melt the solder that connects the filament to the end caps.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 »</TD></TR><TR><TD CLASS="quote">today i finally rewire the RCA cable and when i pulled the old one off, i accidently torn the tiny blue wire apart. so i reconnected everything and the bass stays when the car is not moving, but while im driving, the bass always come on and off. what could the problem be?
uh.. get new RCA's if you tore them apart..?
</TD></TR></TABLE>uh.. get new RCA's if you tore them apart..?
the one i torn apart was actually the remote wire. i connected them back to harnness and it worked fine!!
and i think i found the reason why the bass came on and off!@!!!! it might sound ridiculous tho..
so today the bass completely went dead. so i was about to double check the wire tomorrow to make sure its a loose connection. so after i got off work at night. i started my car and turned on the headlight. i noticed that the driver side headlight is not producing light. then i got off the car and took a look at it and the bulb came off from the headlight bracket and it was hanging there. the plastic got deform.. therefore, i took off the bulb to prevent more damage to the headlight housing... suprisingly my amp came back to normal and the bass stays on OMG!! this is so ridiculous.... how could that affect the amplifier?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">uh.. get new RCA's if you tore them apart..?</TD></TR></TABLE>He said "LITTLE" blue wire... sounds like the remote wire to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 »</TD></TR><TR><TD CLASS="quote">the one i torn apart was actually the remote wire.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Anthony »</TD></TR><TR><TD CLASS="quote">He said "LITTLE" blue wire... sounds like the remote wire to me.</TD></TR></TABLE>^^^The #1 reason it pays to read ahead before posting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 »</TD></TR><TR><TD CLASS="quote"> how could that affect the amplifier?</TD></TR></TABLE> A short in the cars electrical system can drop voltage below the amps limits, shutting the amp off.
94
94
i assume people would know the little blue wire is the remote wire. anyway, the new RCA cable (stinger dream) doesnt have any blue wire. its all blk and purple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> A short in the cars electrical system can drop voltage below the amps limits, shutting the amp off. 94</TD></TR></TABLE>
can you explain this
94</TD></TR></TABLE>For that to happen we are talking about some serious current draw. I would look for burnt or melted wires. Maybe the idiot that hooked the amp up somehow hooked it to the headlight supply? *shrug*
its got nothing to do with the headlight, the light bulb just came off and was hanging on the housing. it was burning the housing so i removed the bulb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 »</TD></TR><TR><TD CLASS="quote">its got nothing to do with the headlight, the light bulb just came off and was hanging on the housing. it was burning the housing so i removed the bulb</TD></TR></TABLE>OIC. I thought you meant the bulb plug was melted, indicating a short...
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">well if he knew it was the remote wire he could have just said so. And, rca's also have a blue wire jackass.</TD></TR></TABLE>
1. It's common sense that "the little blue wire" is remote wire.
2. Not all rca's have a blue wire "jackass".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jli18 »</TD></TR><TR><TD CLASS="quote">hmmm, the amp is off again. so i dont think the headlight matters.. what could the problem be?
</TD></TR></TABLE> Have you checked the other possibilities I mentioned?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">Well it's a good bet it's a loose connection, try turning on the system and then moving the wiring, [power, ground, amp control, RCAs and speaker leads] on the amp around a bit, tap hard on the amp itself.
The other thing I would check is the main power fuse, [by the batt.] if it is an "AGU" fuse holder, like this... http://www.scosche.com/efx.asp...P8FHI replace the fuse, even if it looks good, the AGU, [glass barrel fuse] the fuse filament can break or the fuse can get hot enough, [sub bass cranked] to melt the solder that connects the filament to the end caps. 94</TD></TR></TABLE>
94
</TD></TR></TABLE> Have you checked the other possibilities I mentioned?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">Well it's a good bet it's a loose connection, try turning on the system and then moving the wiring, [power, ground, amp control, RCAs and speaker leads] on the amp around a bit, tap hard on the amp itself.
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a_s_ol_ »</TD></TR><TR><TD CLASS="quote">1. It's common sense that "the little blue wire" is remote wire.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">i didn't say every rca had a blue wire did i?
Oh, No, i didn't.</TD></TR></TABLE>Ok, that is a reasonable answer to option #2. Option #1 had no response. Lack of common sense?
coneheadsracing
Audio / Security / Video
Apr 5, 2008 08:28 AM
