door lock wiring
Old Jul 24, 2006 | 06:14 PM
alex_s817's Avatar
Default door lock wiring
i am installing a keyless entry system in my 94 integra ls and the directions are horrible. the kit is universal and shows many diagrams for various power door lock configurations. the ones listed are, negative trigger door lock wiring, positive trigger door lock wiring, reverse polarity door lock wiring, and aftermarket acutator wiring. then on seperate page, there are two diagrams for seperate driver's door unlocking. the two listed on that page are driver prioritywith negative type locks, and driver priority with reverse polarity locks. i will know what to do if someone can please help to point me in the right direction but i do not know what set up i have on the car, or what diagram to use in order to hook things up correctly.
any help is greatly appreciated
thanks
Old Jul 24, 2006 | 07:03 PM
B18C_EJ8's Avatar
If the car originally came with keyless and has power locks, then it should just be neg trigger locks... You should just be able to connect your lock/unlock wires from the brain to the Black/White (lock) and Black/Red (unlock) in the Driver kick...
Old Jul 24, 2006 | 07:04 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: door lock wiring (alex_s817)
Does your teg have power door locks.
Old Jul 24, 2006 | 08:03 PM
alex_s817's Avatar
Default Re: door lock wiring (wrx-killer-Sti eater)
it didnt come with the factory keyless entry or alarm. i do have power locks, but the wiring diagram that came with my kit is very confusing. and it is also universal
Old Jul 25, 2006 | 01:04 AM
okay first what kind of alarm is it ? Your car is neg trigger and the wires are found in the driver door kick pannel. Neg trigger means it takes ground to trigger your doorlocks- to make them unlock or lock. They will only test from the pass door. Most alarms you can plug directly into the door lock providing that they give a ground for your lock and unlock. Post pics of your alarm diagram and we can point you from there. B18c posted the info thou. Follow the neg trigger diagram from your alarm.
Old Jul 25, 2006 | 06:53 AM
fcm's Avatar
fcm
Old Fart
http://www.directwholesale.net...eID=6 94
Old Jul 25, 2006 | 08:37 AM
alex_s817's Avatar
Default Re: door lock wiring (fcm)
it is a crimestopper keyless entry. code number 865rke.11 if you go onto their site, http://crimestopper.com/, and click on manuals, under keyless entry ( the last link in that category) there is the pdf file which shows the same exact manual i have. pages 5 and 6 are the ones showing the various lock wiring diagrams. i couldnt get this to link or i would just post the pics up. i appreciate the help and if you do take the time to go on there it would be way helpful
thanks
Old Jul 25, 2006 | 09:54 AM
fcm's Avatar
fcm
Old Fart
The first one, [Negative Trigger Doorlock Wiring] is the one you want to use. 94
Old Jul 25, 2006 | 09:00 PM
alex_s817's Avatar
ok thanks alot, do you guys know if i will be able to find all of these wires in the driver's kick panel, or will i have to run them into the door?
Old Jul 25, 2006 | 09:39 PM
in the drivers kick pannel, they test with the passenger door switch only
Old Jul 25, 2006 | 11:37 PM
alex_s817's Avatar
thanks a ton guys, helped a lot
dragon_lowrider
Dec 20, 2010 05:36 PM
DMF
Jun 8, 2005 06:23 PM
japspecnegro
May 9, 2005 06:04 AM
