Compression Test For LS Civic
So Couple hours ago I did the test and most cylinders were 130 and up thats not good huh?
well so what can i do to fix this, should I buy new piston rings or what else could cause it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpeK_EM1 »</TD></TR><TR><TD CLASS="quote">unplug ur fuel injectors also, hold throttle wide open, and make sure ur engine is warm, let it crank about 5 times </TD></TR></TABLE>
Crank until it doesnt seem to increase anymore, a LS should he 180-190
if ur refering to the pr3's from a b16, it will be high compression since b16's are 10 to 1 compression stock. High rev, no torque. Ur LS is a torque motor, get LS pistons if u wanna feel the power
well, i have a 2000 si w/b16a2. i guess i have the pr3's ur talking about since they're stock. Well, my compression is 10:1. 160hp, 116lbtq. and i have to use 91 octane gas or higher or else my engine will knock.
My friend has a LS with the b18b1. Rated 140hp i think with 128lbtq. Low compression which i believe is 9:1. it redlines at 6800 while my car redlines at 8000. Its pretty much if u have low compression, u have more tq than a high compression. i mean the LS integra has mor tq than a GSR. But less than a Type R. I believe GSR have 126, and Type Rs have 132. Well, thats pretty much what i know.
pr3's will give you high compression, you might feel a slight power gain, but with high compression comes high octane gas, otherwise you will be looking at detonation, also I would not rev a stock LS bottom end past 7500rpm and really 7500rpm is pushing it, the rods are a bit weak, but the torque on it is fantastic, personally I would go ahead and run a small turbo with like 7psi, it would give you the bump in hp like a vtec motor and turbo's are fun especially an ls turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elguluso »</TD></TR><TR><TD CLASS="quote">pr3's will give you high compression, you might feel a slight power gain, but with high compression comes high octane gas, otherwise you will be looking at detonation, also I would not rev a stock LS bottom end past 7500rpm and really 7500rpm is pushing it, the rods are a bit weak, but the torque on it is fantastic, personally I would go ahead and run a small turbo with like 7psi, it would give you the bump in hp like a vtec motor and turbo's are fun especially an ls turbo</TD></TR></TABLE>
the rods are fine. its the rod bolts that are the weak link in most honda motors
if you have arp rod bolts you can rev to 7500
jdm bullshit: with those compression numbers your motor is fine
Honda_Cribb_GS-R
25
Sep 10, 2008 04:05 PM
Sprockets
Jan 23, 2003 07:01 PM
