passanger side window not working
on my brothers 93 civic he has a problem with his pass side door window he ca put the window up and down with the driver side. i have a 95 civic we switched out both side switchs and it isnt those cause they work in my car.. so my question is what could be causing them to not work from the pass side.... sorry if this is hard to read trying to type it fast
Thanks for the replys in advance
~Shaun
~Shaun
yah we have the door panel off but what i dont understand is when we try it from the pass. side it doesnt work not even a grind or motor noise a all... but when i hit it from the driver side it goes up i was thinking somthing is wrong with that safty switch on the driver side unit, but we swaped out one out of my car to my brothers.. and it still didnt work.. we gonna take the glove box and stuff off and trace the wire
i would start by checking the fuse (number 8) under dash then if you have the tools check for continuity of the blue and black wire coming from the fuse box straight to the passenger switch
einzelherz
Dec 16, 2011 02:58 PM
