mixing engine oils
Old Jul 17, 2006 | 05:16 AM
EG type GTR
Guest
Posts: n/a
Default mixing engine oils
is it ok to mix 2 different oil brands with the same weight? i forgot exactly what motor oil was put but it was 10-40. my oil level is kinda low so i need to put some in. can i just go and get a 10-40 or it has to be the same exact brand and type?
Old Jul 17, 2006 | 05:21 AM
Jorsher's Avatar
No there will be INTERNal CombuSTION!!!11
Shouldn't matter. Same weight it'll mix up good.
Old Jul 17, 2006 | 05:30 AM
EG type GTR
Guest
Posts: n/a
anybody confirm this?
Old Jul 17, 2006 | 05:35 AM
PooM's Avatar
I do it all the time, as long as its the same weight it will mix up fine. Just different brands have different additives to protect your engine. So its best to stick to one, if you want to change brand, do an oil change
Old Jul 17, 2006 | 05:36 AM
EG type GTR
Guest
Posts: n/a
we just put oil in yesterday but we ran out. so yeah
Old Jul 17, 2006 | 08:38 AM
Targa250R's Avatar
be professional
Default Re: mixing engine oils (EG type GTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG type GTR &raquo;</TD></TR><TR><TD CLASS="quote">is it ok to mix 2 different oil brands with the same weight?</TD></TR></TABLE>
Yes.
I've mixed oils that are neither the same brand, weight, or even base.
Old Jul 17, 2006 | 08:45 AM
GottaLoveHondas's Avatar
Default Re: mixing engine oils (Targa250R)
Shouldn't be a problem, my brother used to run a oil change shop and he says its ok to do that, especially if it means messing up your motor by having no oil in the thing. So yeah, looks like you did it already so ok
Old Jul 17, 2006 | 09:16 AM
ssbpturbohatch's Avatar
Default Re: mixing engine oils (GottaLoveHondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLoveHondas &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't be a problem, my brother used to run a oil change shop and he says its ok to do that, especially if it means messing up your motor by having no oil in the thing. So yeah, looks like you did it already so ok </TD></TR></TABLE>
I've told her this a lot
Uncle Ben's
Aug 14, 2005 09:29 AM
B-A-N-A-N-A-S
May 20, 2005 06:34 PM
JimmyAtlantis
Feb 21, 2004 08:10 AM
Blue-Civic-Hybrid
Jun 23, 2003 03:19 PM
KooK
Jun 9, 2002 03:41 PM
