mixing engine oils
Guest
Posts: n/a
mixing engine oils
is it ok to mix 2 different oil brands with the same weight? i forgot exactly what motor oil was put but it was 10-40. my oil level is kinda low so i need to put some in. can i just go and get a 10-40 or it has to be the same exact brand and type?
I do it all the time, as long as its the same weight it will mix up fine. Just different brands have different additives to protect your engine. So its best to stick to one, if you want to change brand, do an oil change
be professional
Re: mixing engine oils (EG type GTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG type GTR »</TD></TR><TR><TD CLASS="quote">is it ok to mix 2 different oil brands with the same weight?</TD></TR></TABLE>
Yes.
I've mixed oils that are neither the same brand, weight, or even base.
Yes.
Re: mixing engine oils (Targa250R)
Shouldn't be a problem, my brother used to run a oil change shop and he says its ok to do that, especially if it means messing up your motor by having no oil in the thing. So yeah, looks like you did it already so ok
Re: mixing engine oils (GottaLoveHondas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GottaLoveHondas »</TD></TR><TR><TD CLASS="quote">Shouldn't be a problem, my brother used to run a oil change shop and he says its ok to do that, especially if it means messing up your motor by having no oil in the thing. So yeah, looks like you did it already so ok </TD></TR></TABLE>
I've told her this a lot
JimmyAtlantis
02-21-2004 08:10 AM
