i don't think my HKS SSQV is installed right
Old Jul 16, 2006 | 01:40 PM
spooncivic1's Avatar
Default i don't think my HKS SSQV is installed right
I recently had a problem with my SSQV, the c-clip that holds the BOV in place on the flange was a little too big...i got that problem solved, and i got the BOV in the flange now with the o-ring in place
but my question is, that the bov isnt really that tight in place inside the flange, i can spin it around by hand....i'm just afraid that its going to leak boost once i get my turbo kit installed
Old Jul 16, 2006 | 01:42 PM
Bee18see's Avatar
Default Re: i don't think my HKS SSQV is installed right (spooncivic1)
it probably depends how much boost your going to run..but its still probably a good idea to find a way to tighten it
Old Jul 16, 2006 | 01:51 PM
well i mean, there isnt really another way to tighten it
its only held in place by the clip...i guess i could always throw some JBweld around where the clip is
Old Jul 16, 2006 | 03:18 PM
slodc2's Avatar
its fine...my friend's spins around too...he has no boost leak problems
Old Jul 16, 2006 | 03:32 PM
non-VTEC's Avatar
the BOV should not spin around once the snap ring is installed.......something is not right......maybe you put the snapring upside-down?
Old Jul 16, 2006 | 03:37 PM
Default Re: i don't think my HKS SSQV is installed right (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the BOV should not spin around once the snap ring is installed.......something is not right......maybe you put the snapring upside-down?</TD></TR></TABLE>
there is no up or down its all the same. a c-clip holds the bov down.
Old Jul 16, 2006 | 05:01 PM
A.E Motoring's Avatar
on C clips some there is a up and down, i used to work at Vortech, i use to make blow off valves, if its the same kinda snap ring, then one side should be completely flat and the other side a lil rounded, your going to want to use the flat side when installing, hope that helps, im not saying im right but its worth a shot
Old Jul 16, 2006 | 05:14 PM
Default Re: i don't think my HKS SSQV is installed right (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">on C clips some there is a up and down, i used to work at Vortech, i use to make blow off valves, if its the same kinda snap ring, then one side should be completely flat and the other side a lil rounded, your going to want to use the flat side when installing, hope that helps, im not saying im right but its worth a shot</TD></TR></TABLE>
when i got it, both sides were flat..
i'm just gonna get someone to pressure test it before i put it on and hit the dyno
Old Jul 16, 2006 | 06:17 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">
there is no up or down its all the same. a c-clip holds the bov down.</TD></TR></TABLE>
on my HKS SSQV BOV the instructions said to install the snap ring the right side up. both sides are NOT flat. one side has a "bump" on it and i "think" it said it must face up or the BOV will not seal correctly....
someone with the instruction sheet should be able to tell you for sure.....
Old Jul 16, 2006 | 06:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">on my HKS SSQV BOV the instructions said to install the snap ring the right side up. both sides are NOT flat. one side has a "bump" on it and i "think" it said it must face up or the BOV will not seal correctly....
someone with the instruction sheet should be able to tell you for sure..... </TD></TR></TABLE>
well i might need to go double check the clip then.
Old Jul 16, 2006 | 09:42 PM
turbotime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">I recently had a problem with my SSQV, the c-clip that holds the BOV in place on the flange was a little too big..</TD></TR></TABLE>
Are you sure it was too big? If it came with the BOV im pretty sure it was the right size.... you need to take the outer housing off to install the HKS bov with the snapring, the one that you didnt use is the correct one, use it and u will have no more issues....idk if there is an up down, mine was perfectly flat
My HKS SSQV is does not spin either.
Old Jul 17, 2006 | 11:30 AM
there was no way the clip would even go into the flange. even with the snap ring pliers...
if it leaks then i'll take some JB quick, and slap it around the base of the BOV so it can't leak anymore
bboysake
Aug 3, 2006 02:41 PM
Turbo D17
Dec 12, 2004 12:06 PM
oemDC2
Feb 26, 2004 08:03 PM
BlackB18CTeg
Oct 4, 2003 11:16 AM
