d15b vtec in 00 hatch
im got the motor and trans ecu and a 00 civic ex wiring harness. im about to buy the jumper harness to go to obd1. my question is do i need new axles? or are mine gonna work in the d15b tranny? also will the ex harness work fine? plz help thank you
everything will work fine. the dizzy plug will be differant than yours so you will either have to repin the dizzy on the motor and use your plug, or use the plug on the harness that comes w/ the motor and wire into your harness. other than that its plug and play, might have to move a couple wires around unless you use the stock ex manifold and throttle body (which i would do) because the iat sensor is in a differant spot.
Phat4Door
Sep 28, 2010 06:08 AM
SkRiBLaH
12
Jun 23, 2006 05:43 PM
JDM Style EK
Sep 23, 2003 12:03 AM
bump
