Will 01 gsr sway bar fit on 93 cx hatch
Old Jul 12, 2006 | 10:47 AM
r3sgtec's Avatar
Default Will 01 gsr sway bar fit on 93 cx hatch
i went to put on gsr sway bar onto a 93 hatch, and couldnt find where to bolt it on to. do i have to drill holes? if so, where? can anyone help? i want to install asap..
Old Jul 12, 2006 | 11:37 AM
jdm b18c ek4's Avatar
Default Re: Will 01 gsr sway bar fit on 93 cx hatch (r3sgtec)
i think u need new LCA's (not sure)
Old Jul 12, 2006 | 11:49 AM
r3sgtec's Avatar
Default Re: Will 01 gsr sway bar fit on 93 cx hatch (jdm b18c ek4)
o damn...that sucks...
Old Jul 12, 2006 | 11:51 AM
thacivicguy's Avatar
B A N N E D
i think it could be done, not sure or use ctr
Old Jul 12, 2006 | 11:54 AM
r3sgtec's Avatar
Default Re: Will 01 gsr sway bar fit on 93 cx hatch (thacivicguy)
ctr?...i also found this...http://importnut.net/swaybar.htm
Old Jul 12, 2006 | 01:43 PM
r3sgtec's Avatar
so i figured out that it isnt possible to do it, but is it safe to drill holes in the lca's so that it will work, like the other bolts line up, just not the ones for the lca's. is it ok to drill through it?
Old Jul 12, 2006 | 01:45 PM
krisjk2's Avatar
i would go against drilling your lca's, you will make them weaker and they will ultimately snap later on. also ctr= civic type r
Old Jul 12, 2006 | 02:13 PM
r3sgtec's Avatar
Default Re: Will 01 gsr sway bar fit on 93 cx hatch (Muttly)
cool thanks, thats what i figured...
Old Jul 12, 2006 | 02:34 PM
Relic1's Avatar
DC2 sways work fine on EGs.
you need LCAs that have the sway bar holes though.
BTW, are you talking front or rear? (both work but it takes different parts, for obvious reasons)
Old Jul 12, 2006 | 06:57 PM
r3sgtec's Avatar
Default Re: (Relic1)
just talking about the rear..
mynameizstitch
Jul 20, 2009 09:39 PM
wdskuk
Aug 21, 2003 10:35 PM
racin-type
Apr 23, 2003 04:48 AM
Sleepercivic2
Feb 16, 2003 04:52 PM
hybridcivic93cx
Apr 24, 2002 12:35 PM
