GSR sway bar on a 93 cx hatch
I am going to install GSR LCA'a in the front of my hatch. I am also installing the gsr calipers and brakes as well. Will the car become unsettled if i also install the gsr sway bar? Does it fit in the fifth gen hatch? What ever the answer, at least i now have the sway bar mounting points on the front lca's. Anyone running just the front sway bar and no rear bar? Thanks
Re: GSR sway bar on a 93 cx hatch (hybridcivic93cx)
Most people just run the rear sway bar. Running JUST the front sway bar would create toooo much under steer. Do a search and there will be some more results. Good Luck.
What's the best setup for AEM anti sway bars?
Is that ITR back too aggressive. What front bar is best with what back car?
I was thinking ITR rear bar with GSR front bar or 92-95 Civic Si front bar.
Re: GSR sway bar on a 93 cx hatch (MaxBoost)
What sway bars you run and how it will handle also depends on what spring rates you're running. The stiffer you make the rear of the car(with stiffer springs or a bigger sway bar), the more prone to oversteer your car will be. The factory integra parts are great bars, and fit on them. I run 375 front springs and 450 rear with a gsr/itr front bar, and a itr rear bar, and Koni adjustable shocks. I can tune out some over/understeer by playing with the shock settings. Lots of fun.
Re: GSR sway bar on a 93 cx hatch (jg)
sorry to butt-in on your post but i just had a quick question. i installed neuspeed koni yeloows, eibach sportlines and gsr rear LCA's with ES bushings. i am now installing a gsr rear sway bar (free=good). do i need any subframe reinforcement kit for this or do i just switch the stock gsr mouting brackets and drill the holes for them in my subframe? thanks for the help.....
CHRIS
CHRIS
Re: GSR sway bar on a 93 cx hatch (deviant94ex)
CHRIS
CHRIS
Gunmetal_B20_Hatch
Suspension & Brakes
10-16-2005 07:41 PM
Andrew 825SM
07-07-2003 01:19 PM
