b18c obd question
cute little bastard
Re: b18c obd question (novvti)
You know you need a conversion harness right?
Also it depends on what kind of ECU I think and/or if you're missing any sensors.
Re: b18c obd question (SkoundrelUSA)
it depends on which make and model vehicle you have?!
obd1 is 92-95
obd2a is 96-98
obd2b is 99-00
if you have a 92-95 then that swap will work perfectly!
96-98....you'll need the conversion harness for the ecu same for the 99-00
they both are different!!
it won't throw any cel codes unless you have some defective parts on your swap!?!?
gl
obd1 is 92-95
obd2a is 96-98
obd2b is 99-00
gl
If you don't have VTEC pressure switch because it's a JDM GSR or ITR, you might want to check out phearable.net and talk to John Vega. Buying a conversion harness needs to be altered a little.
EvasiveMotorsports.com
Performance
17
10-30-2009 02:51 PM
PY01ITR42
07-12-2002 10:37 PM
