Will 01 gsr sway bar fit on 93 cx hatch
i went to put on gsr sway bar onto a 93 hatch, and couldnt find where to bolt it on to. do i have to drill holes? if so, where? can anyone help? i want to install asap..
Re: Will 01 gsr sway bar fit on 93 cx hatch (thacivicguy)
ctr?...i also found this...http://importnut.net/swaybar.htm
Re: Will 01 gsr sway bar fit on 93 cx hatch (r3sgtec)
so i figured out that it isnt possible to do it, but is it safe to drill holes in the lca's so that it will work, like the other bolts line up, just not the ones for the lca's. is it ok to drill through it?
i would go against drilling your lca's, you will make them weaker and they will ultimately snap later on. also ctr= civic type r
DC2 sways work fine on EGs.
you need LCAs that have the sway bar holes though.
BTW, are you talking front or rear? (both work but it takes different parts, for obvious reasons)
mynameizstitch
07-20-2009 09:39 PM
wdskuk
08-21-2003 10:35 PM
racin-type
04-23-2003 04:48 AM
hybridcivic93cx
04-24-2002 12:35 PM
