boosting then a loud bang
Old Jul 11, 2006 | 06:47 PM
94siludeturbo's Avatar
Default boosting then a loud bang
i have a H23a1 with a turbonetics t3/t4 turbo i just up the boost and jump some numbers up on the SAFC when i boost and hit around 5k rpms i have a loud bang and some black smoke came out ran the car up the road seems to run fine then tried it again and same thing....car runs fine now but why was it doing it i went from 3lbs(all the auto tranny could handle before i swapped a 5 speed in) and i boosted up to 7 lbs and then got the bang. tried retarting the timing a few degrees still didnt help any ideas on the issue
and does anyone have the ideal settings for the SAFC for 7lbs. other mods include msd sci, blaster 2 coil, and plug wires. vortec fmu and regapped my plugs to .030 any ideas
Old Jul 11, 2006 | 07:00 PM
bb_one's Avatar
Default Re: boosting then a loud bang (94siludeturbo)
This sounds like a nightmare.
So aftering hearing a loud bang from your motor after messing with the boost levels/fuel adj., you decided to try it again?
Has your SAFC been properly tuned? If you're just tuning by ear, sight, or feel, I think you are very fortunate to have the motor still running fine.
Do you have a wideband O2 to monitor what your A/F ratios are?
The SAFC is already a poor choice of engine management. Your best bet is to ditch the SAFC and go with something more useful (Chrome, Uber, HONDATA, Neptune, or AEM) then send it to a tuner to get it tuned, the right way.
Was the "bang" more like a ping? If your engine was pinging, then you're running into pre-detonation (very bad).
Old Jul 11, 2006 | 07:05 PM
yeah ive check everything and motor seems to be fine plugs still show normal color so i knwo im now lean or way to rich could it be something with the ignition
Old Jul 11, 2006 | 07:09 PM
bb_one's Avatar
Default Re: (94siludeturbo)
What are your A/F ratios?
Old Jul 11, 2006 | 07:18 PM
i do not currently have a Wideband o2 sensor but i check the plugs pretty much daily seems to be ok not white(lean) or to black (rich) they are the color they are spose to be
Old Jul 11, 2006 | 10:20 PM
PrecisionH23a's Avatar
It's your engine telling you to stop raping it.
The ideal setting for the afc and fmu would be in the garbage. It sounds to me like the car is running pig rich. You are just asking to blow your engine... so I would highly recommend taking it to a shop and having it tuned with a decent EMS.
Old Jul 11, 2006 | 10:39 PM
bb_one's Avatar
Default Re: boosting then a loud bang (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">It's your engine telling you to stop raping it.
The ideal setting for the afc and fmu would be in the garbage. </TD></TR></TABLE>
Amen.
Old Jul 11, 2006 | 10:45 PM
98vtec's Avatar
moderator emeritus
its your car telling you to give it to someone who will treat it better.
"No damnit, i said stop it!"
Old Jul 11, 2006 | 10:51 PM
98vtec's Avatar
moderator emeritus
Default Re: boosting then a loud bang (98vtec)
but seriously. You need to get your car tuned.
what injectors are you running?
an afc and fmu is no way to treat a turbo motor.
Old Jul 12, 2006 | 04:42 AM
Pullig's Avatar
if you just have to run the safc get some 450s ditch the FMU ... but the best would be hondata or if you want to be cheap like me run crome it works amazing.
Old Jul 12, 2006 | 06:24 AM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Re: boosting then a loud bang (Pullig)
Old Jul 12, 2006 | 06:28 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
sounds like a **** poor heart broken motor.....with probably a td05 turbo mani you bolted on?? am I right???? wow probably a backfire.....means you tune like ****...GT3 tuning and real life tuning are different...pay a shop your motor may recovery from this abuse...................or you can keep beating it to "see if it happens again"
poor poor motor
Old Jul 12, 2006 | 07:47 AM
Eddiebx's Avatar
maybe the bang is telling you to turn up the boost,
Old Jul 12, 2006 | 02:22 PM
thaiswirls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">probably a backfire.....</TD></TR></TABLE> yea i think its backfiring as well... take it to someone who does tuning...
Old Jul 13, 2006 | 03:56 AM
H20too's Avatar
The ideal setting for the afc and fmu would be in the garbage. It sounds to me like the car is running pig rich. You are just asking to blow your engine... so I would highly recommend taking it to a shop and having it tuned with a decent EMS.</TD></TR></TABLE>
thanks for the new sig quote!!
LST2
Jul 10, 2007 06:15 PM
94siludeturbo
Jul 11, 2006 07:21 PM
drintegra
May 22, 2006 05:26 AM
KJ
Jul 2, 2001 07:54 AM
