Sloppy shift linkage in my ek
Old Jul 11, 2006 | 04:59 PM
EkCivic282's Avatar
Default Sloppy shift linkage in my ek
Alright i got a 00 EK with a GSR swap. my shifter moves way to much in gear i replaced the bitch pin and it did improve but still is pretty sloppy in gear does any one know whats wrong???
Old Jul 11, 2006 | 05:11 PM
luelf21's Avatar
There are two rubber couplings that may be missing that causes play in the shifter while in gear. You really shouldnt worry about it unsless it just annoys you, or just buy an aftermarket shifter. It should take care of the problem.
Old Jul 11, 2006 | 05:14 PM
LR's Avatar
LR
Default Re: (luelf21)
replace your shifter bushings. at first it might be hard to get into gear at first, but it will soon lossen up to make shifts alittle easier. thats should slove your probelm..
Old Jul 11, 2006 | 05:38 PM
EkCivic282's Avatar
thanks ill probably just by a new short shifter and new shifter bushings
Old Jul 11, 2006 | 05:40 PM
sicky's Avatar
grammer nawzi
Default Re: (EkCivic282)
Sounds like your bushings, as stated above.
turbo-crx
Transmission & Drivetrain
Aug 26, 2009 05:21 AM
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
---SPEED-DEMON---
Sep 16, 2008 09:18 AM
jbscivichb92
Nov 18, 2004 01:03 PM
sloweh3
May 7, 2004 04:34 AM
