what could this be!!!!! stop light, shit load of blue smoke!!!!(oil)
what could this be!!!!! stop light, **** load of blue smoke!!!!(oil)
hey so i have this 93 civic, jdm head, i/h/e and fluidyne radiator, more minor **** but dont feel likeisting it
so anyways, ive had his rear main seal leak for about 2 months, then i went to add some oil today, overloaed a lil, so i was driving, i need more time in a ******* day im too rushed, and but 6 miles? or so? my car just fills up with blue smoke i mean like i was blinding other drivers and almost caused an accident, so i parked over the side of the road waited for my dad etc, so we start it to get it to a safe place, its continupusly burning oil
my dad said check the head gasket, i sadi it might be the rings or the valve guides whos right? any other suggestipns?
ps its bout 7 miles from my hous right now, im going to do a compression test once it gets towed over here
any thing else?
any thing else?
Re: what could this be!!!!! stop light, **** load of blue smoke!!!!(oil) (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">do compression test, you might have blown your seals...
but how much more oil did you put? even if it's a quart over, it wouldn't damage it that bad...</TD></TR></TABLE>
but if its 2-3 quarts over it can be bad, real bad. but HG is my first guess
Re: what could this be!!!!! stop light, **** load of blue smoke!!!!(oil) (Sleepy_Red_hatch)
Well if you guess headgasket, check for syptoms, losing coolant, conbustion gasses in the overflow tank, over heating.
Re: what could this be!!!!! stop light, **** load of blue smoke!!!!(oil) (Turbo_y8)
and also, pull the crankcase vent line (the line from the valve cover to the intake) and see if smoke comes out of the. If it does, oil rings are shot.
i have brether there, ummm about that like 2 quarts over,
Modified by civicfast at 12:31 AM 7/11/2006
Re: what could this be!!!!! stop light, **** load of blue smoke!!!!(oil) (civicfast)
the breahter is doing more damage then it is looking cool. How is your crank case suppose to vent?
do you mean out of the front of the block/head or like from under the hood?
exhaust leak found, major, smoke coming from exhaust leak and out the tail pipe
Modified by civicfast at 12:32 AM 7/11/2006
Re: (civicfast)
if its coming out from under the hood its coming out that breather filter. It could be rings, valve seal or scored cylinder walls that would creat excessive blow by
Re: (Turbo_y8)
aight compression test
135
150
120
125
im in the process of pulling of the head, but diidnt have much time, tommorow itll be off and ill take a look, as those testts are low
135
150
120
125
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 »</TD></TR><TR><TD CLASS="quote">and also, pull the crankcase vent line (the line from the valve cover to the intake) and see if smoke comes out of the. If it does, oil rings are shot.</TD></TR></TABLE>
Smoke from the breather does not mean rings. It could just as easily be valvestem seals.
I would replace the seals first, since they are only 4 bucks each. If it still burns oil, do the rings.
Re: what could this be!!!!! stop light, **** load of blue smoke!!!!(oil) (drumminforev)
but the valvestem seals have to be pressed in right? wouldnt that shoot the price up some more, its also a sohc jdm vtec head i think it has around 60k on it would they go bad after that? short block has 260k+
expletive, thats going to be expensive huh? we;; im doing all the work my self, how much/ hard is it to install rings?
Involves taking the pistons out, which means the whole bottom end apart, and itd be very wise to hone the cylinders or even bore over. You wont be able to do all the work yourself. You could strip the bottom end though, get you pistons and rings, and bearing kit, take ti to a shop and have them do the rest.
Re: (civicfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicfast »</TD></TR><TR><TD CLASS="quote">no air either
my dad builds **** outta wood and really has no automotive tools, was lucky he had a compression tester, actually i was like dad go try to take the crank bolt off, and he was like ok, so i hold the brake for him, i come out and hes ******* spinning the cam shaft, im like wtf r u doing and he starts yeling like im going to junk the ******* car dammit! its a pieace of ****! then my bro was scratchingm y car just to be a lil bitch, like my car needs another champ white paint job, i said dont scratch it, my dad goes well if ur going to scratch it im going to junk it, wtf he drives a 97 accord dented up with 300k+ miles on it and says i have a pieace of ****, mines a 93 ex </TD></TR></TABLE>
you're weird
you're weird
