CEL 71 - 74, Random Misfire all 4 cylinders. Need help
Old Jul 6, 2006 | 12:42 PM
BLacK FirE's Avatar
Default CEL 71 - 74, Random Misfire all 4 cylinders. Need help
Alright so a couple months back I was getting CEL 72, random misfire cylinder 2. Eventually it was a constant misfire and turned out I had a chipped exhaust valve. Foward to now, head is back on and fixed, but now I'm throwing CEL 71 - 74, Random Misfire in all 4 cylinders. But the misfire is not audible and the car drives fine.
I've changed the spark plugs, wires, cap and rotor. I also pulled the injectors out and cleaned them best I could. I just tested the ohm readings on my ignitor coil and it's fine. I can't figure this out. Any other suggestions?
Old Jul 6, 2006 | 04:20 PM
BLacK FirE's Avatar
Default Re: CEL 71 - 74, Random Misfire all 4 cylinders. Need help (BLacK FirE)
bump for answers
Old Jul 6, 2006 | 04:42 PM
yee SERIOUS's Avatar
what's your timing at?
Old Jul 6, 2006 | 07:41 PM
kiddcarbuff's Avatar
did you have alot of gas when you started to misfire on cyl #2?? this happened to my buddy in his gsr, he was beating on it w/ like no gas and it spit and threw a cel, would rev past 7 grand, filled it up, disconnected the battery and ecu for 10 mins and preto it ws fine. hope that helps a lil
Old Jul 6, 2006 | 10:02 PM
BLacK FirE's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">what's your timing at?</TD></TR></TABLE>
Everything with timing is good. Teeth are lined up and ignition timing is right on the money at 16 degrees.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">did you have alot of gas when you started to misfire on cyl #2?? this happened to my buddy in his gsr, he was beating on it w/ like no gas and it spit and threw a cel, would rev past 7 grand, filled it up, disconnected the battery and ecu for 10 mins and preto it ws fine. hope that helps a lil</TD></TR></TABLE>
I don't have the misfire in cyl 2 anymore. I replaced the exhaust valve, but after putting everything back together I'm getting a "random misfire" in cylinders 1 through 4, but it's not audible and doesn't seem to actually be missing at any point.
Old Jul 7, 2006 | 01:48 AM
1337whp's Avatar
Default Re: (BLacK FirE)
i've had the same problem for like 2 weeks now. i cant hear or feel it it just throws the same codes. any other ideas? car runs fine except for a low idle sometimes. i plan on comse maintence this weekend which should hopefully help.
Old Jul 7, 2006 | 08:14 AM
BLacK FirE's Avatar
Default Re: (1337whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote">i've had the same problem for like 2 weeks now. i cant hear or feel it it just throws the same codes. any other ideas? car runs fine except for a low idle sometimes. i plan on comse maintence this weekend which should hopefully help.</TD></TR></TABLE>
Yep forgot to throw that in the idle seems to fluctuate sometimes. But when it goes up to like 800 it'll stay there for a bit. I also found yesterday yesterday a leak from one of my injectors, the o-ring was ripped. So I replaced that this morning, but haven't driven the car since resetting the ecu. I don't think though that was the problem.
Old Jul 7, 2006 | 01:02 PM
BLacK FirE's Avatar
bump still cant figure this out
Old Jul 8, 2006 | 10:55 AM
BLacK FirE's Avatar
Adding this for future people that search:
Seems to be the ecu was the problem. Swapped in a friends and the cel never came back on again. Put mine back in and after 6 miles of driving it was back. So now I just gotta find one to buy.
Old Jul 10, 2006 | 10:18 PM
BLacK FirE's Avatar
bump cause I was wrong about it being the ecu.
Still need help figuring this out.
Old Jul 11, 2006 | 08:17 AM
BLacK FirE's Avatar
bump
Old Jul 11, 2006 | 09:32 PM
BLacK FirE's Avatar
bump, just tried changing the fuel filter, still nothing
Old Jul 11, 2006 | 10:22 PM
93eg2james's Avatar
im the kid that kiddcarbuff was talking about and it lead to a bent exhaust valve, so i'd get crackin on this one. the problem "went away" after i recet my ecu, but it came back to haunt me
my guess is that its something to do with your dizzy. replace the rotor and cap, im willing to bet thats the problem. when rotors get old and tired they dont spin as well causing problems that you're not gonna wanna pay for
fortunatly for me i have a good group of friends and i got a b16a head for next to nothing. if at all possible. dont drive the car till the problem is solved
Old Jul 12, 2006 | 06:57 AM
BLacK FirE's Avatar
Default Re: (97gsrjames)
I already changed the cap and rotor.
Old Jul 13, 2006 | 10:19 AM
96tegls2dr's Avatar
i am having a silimar problem. i just swappe din a b20b becasue my b18b was drinking oil and throwing a cel of misfire in cyl 1 and 3. i contributed that to the fact that my intake temps were reading 152* on the b18. i havent gotten a code since the swap but i have only put about 75 miles on her since. the idle still jump around and i have a slight hesitation when feathering the pedal. basically what happens is the car bogs if i slowly increase the throttle. i know i have a bad cat becasue i can smell rotten eggs at idle. i am attributing this stumble and idle problem to the cat for now. but i am also thinking it could be the cap and rotor. i am going to install a test pipe but need to get an o2 simulator first so i dont throw more CEL's. hopefully the cat is the problem if not ill get a new cap and rotor and if that not it ill burn the damn car. i am frustrated becasue i bought the car and a month later the motor started acting up so i put out the money for the swap and im still having problems. it has to be something i switch over though becasue both motors are having the same idle and hesitation problem
Old Jul 13, 2006 | 10:38 AM
Lauj87's Avatar
sounds like you could have jumped your timeing. do a leak down and compression test. or you might have some how retared your timeing when your sprayed.
Old Jul 13, 2006 | 10:40 AM
96tegls2dr's Avatar
Default Re: (Lauj87)
if that was to me i know my timming is right so that rules that out.
Old Jul 13, 2006 | 10:42 AM
Lauj87's Avatar
Default Re: (96tegls2dr)
doesn't hurt to double check.
Old Jul 13, 2006 | 12:55 PM
BLacK FirE's Avatar
Well I fixed my problem. It was my CFK sensor.
Old Jul 13, 2006 | 01:56 PM
96tegls2dr's Avatar
i am not throwing any codes after the swap and my CFK sensor was swapped over to the current motor. i havent ruled it out yet but when i give it gas it feels great. so for me i believe its either the cat or the cap and rotor. i hope anyway. i hate trying to diagnose a problem that could be multiple things. especially when money is tight!! LOL
bighoss77
Aug 15, 2012 06:54 AM
datflyboy
Apr 10, 2009 11:31 AM
Teglessb18
Oct 3, 2007 08:53 PM
b00sted4dr
Jun 23, 2005 09:17 PM
