clank clank
Old Jul 3, 2006 | 10:13 AM
dj schnitzler's Avatar
Default clank clank
when i pull away from a light i hear this clanking noise coming from the left front. it only happens when i don't quite give it enough gas. kinda sounds like metal rattling.
stock 2000 civic ex mtx 100k
honda-tech powers unite!
Old Jul 3, 2006 | 10:22 AM
cambopheonix56's Avatar
Default Re: clank clank (dj schnitzler)
Probably exhaust related. Mine does the same thing.
Old Jul 3, 2006 | 11:08 AM
Default Re: clank clank (cambopheonix56)
it better not be my exhaust...i just got a new one put on about 10k ago
where do you think the rattling is coming from?
Old Jul 3, 2006 | 11:12 AM
old man neri's Avatar
Probably just a heat shield somewhere that has rusted off. Start poking and proding and you should find it.
Old Jul 3, 2006 | 11:21 AM
Default Re: clank clank (old man neri)
i don't have alot of time to mess around with this car.
that's why i own a honda.
where should i start looking? near the cat?
Old Jul 3, 2006 | 11:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj schnitzler &raquo;</TD></TR><TR><TD CLASS="quote">
where should i start looking? near the cat?</TD></TR></TABLE>
Ya, start at the header, there is a cover there, then the cat, and work your way down. It should only take a couple of min. Heat shields always rust out, rattle, and eventually fall off.
The alternative method is to get a friend to start your car for you and you look and listen for the rattle sound to try to isolate it's location.
Old Jul 3, 2006 | 12:30 PM
it only does it when i'm starting from a complete stop though?
are we talking about the same issue?
just trying to make sure it's not suspension related. i can live with rattles and what not as long as they aren't doing harm to the car itself
Old Jul 3, 2006 | 01:23 PM
Heat shields will rattle at the weirdest moments. It's the first thing I would check out. I am not ruling out that it could be suspension or something else for that matter just that the heat sheilds are the easiest thing to diagnose.
Old Jul 3, 2006 | 02:09 PM
Yea check out the heat shield.
Old Jul 4, 2006 | 04:11 PM
Clairvoyant's Avatar
Where abouts on the car is it coming from? Do you have a set of hubcaps on your rims? I had a problem not too long ago, I have a 1993 Civic LX, which originally had the little center hubcaps. Anyways, it also now has full size 13" hubcaps on, and on a couple of the wheels, the little original 'H' hubcaps were left on. Anyways, one came loose and was rattling in between the rim and larger hubcap. Scared me when I first heard the noise, but as it turned out it was nothing, and it would only happen when starting off from a stop. Hope this makes since and might be something to look at.
spoonef
17
Dec 5, 2005 11:38 AM
starbury
Feb 15, 2005 05:09 PM
EJ8 GSR-T
Oct 28, 2004 05:47 PM
UnionCity LS
Jan 12, 2004 02:45 PM
Toadfart
Dec 18, 2003 01:48 AM
