Tranny issue
I'm not having any luck posting in Tech so I am posting here.
I have a 96 LS tranny with a quaiffe LSD, it seems like something went wrong during installation. the speedo gear that turns the gear on the VSS is not sticking out far enough to turn the VSS gear. how is even this possible? here is a visual aide
Number 6 isnt reaching out far enough to turn the VSS. the Diff fits in a groove so how is this possible?
No, if it was, the VSS wouldnt be able to go in, and even if it was put in backwards it should still stick out far enough to touch the VSS gear because its still physically the same size. this is why fo rteh life of me I cant figure out how its on and doesnt come out far enough.
What kind of bearings did you have the tapered rollers or the enclosed bearings? And what did you put back in it?
Did you calculate what shim you needed to put in there?
