Is something missing from my tranny?
Old Jun 29, 2006 | 11:26 AM
Boostage's Avatar
Default Is something missing from my tranny?
My mph isnt working, cluster and VSS is good, so I took out the entire VSS assembly out and u know how it has gears/teeth at the end? well I looked inside the hole in the tranny and there were no gears/teeth on in there to turn the gear/teeth on the VSS. Kilda like this..
I put my finger in there and felt around and it felt like an empty hole all the way around is it possible that when they took my tranny apart to put in the LSD they forgot to put back in the gear that turns the other gear on the VSS? or is it not even touched when installing an LSD?
Modified by Boostage at 3:44 PM 6/29/2006
Old Jun 29, 2006 | 01:57 PM
non-VTEC's Avatar
Default Re: Is something missing from my tranny? (Boostage)
there should be a gear that turns the VSS gear around the diff.
its a pain in the *** to remove and sometimes they crack when trying to remove.....maybe the place who installed the LSD didn't put the speedo gear on the diff or they broke it.
what really sucks is that the speedo gear is NOT available separately from the dealer.......you have to buy the whole diff which is big bucks...
Old Jun 29, 2006 | 02:02 PM
Boostage's Avatar
Default Re: Is something missing from my tranny? (non-VTEC)
Do u have a pic of it?
Old Jun 29, 2006 | 03:07 PM
_BEN_'s Avatar
BTW: For a 95 civic SI it is called GEAR, SPEEDOMETER DRIVE and is 19.29 I would give them a call and see if the parts are available though because sometimes they are not like mentioned above.
Old Jun 29, 2006 | 03:31 PM
Boostage's Avatar
Default Re: Is something missing from my tranny? (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">#6
BTW: For a 95 civic SI it is called GEAR, SPEEDOMETER DRIVE and is 19.29 I would give them a call and see if the parts are available though because sometimes they are not like mentioned above. </TD></TR></TABLE>
actually its number 6 in that picture that I need, the gear drive is teh gear on the VSS. on my soh ctranny I culd feel that number 6 part, but I cant on the tranny I have a problem with.
Old Jun 30, 2006 | 10:03 AM
NJcoupe's Avatar
What trans is it? I can get you a part # for that speedo gear.
Old Jun 30, 2006 | 10:23 AM
Boostage's Avatar
Default Re: (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">What trans is it? I can get you a part # for that speedo gear.</TD></TR></TABLE>
its a 96 LS trans and today I confirmed that the gear is missing. eithe rthat or off balce, I can see the shiny bearing clear as day, and when I look into my friends b16 tranny I see the gear and cvan feel it when I stick my finger in. I hope this shop fixes this for free because its not my fault.
Old Jun 30, 2006 | 02:33 PM
Andrew's Avatar
Default Re: (Boostage)
sounds like a <u>V</u>ery <u>S</u>hitty <u>S</u>ituation
werd play is nerd play
yungmulacrx
Transmission & Drivetrain
Aug 27, 2013 12:48 PM
hfrex
May 14, 2009 03:20 PM
Boostage
Jul 3, 2006 10:09 AM
Boostage
Jun 29, 2006 12:41 PM
G2ILS
Aug 7, 2005 10:11 PM
