How much will my tune change with 2 different map sensors.
I am about to do some street tuning and I wanna know if i should wait till i get a new 3 bar map sensor, or just do some tuning with my OEM one first...
Ideally i would like to run around 14 psi... but i wanna make it safe for now...
can i just change my map sensor later on using chrome or will it change EVERYTHING?
Munkyw3rkz.webs.com
you can have have the 3 bar wired in later on and still have your OEM map plugged in but only 1 at a time..
yes your tune will be off because it will not be fed the right sigal.....
ok, well i just spliced the wires, so i can run one or the other... but im just wondering if it will really change things when i switch back and forth on the Crome program
Who is Mr Robot?
it will matter because each map sensor is scaled differently. that is, with the same input (vacuum/boost) they output different voltages
Who is Mr Robot?
actually, now that i think about it. it may be all
just depends on how crome rescales things ( i havent played w/ the software in awhile)
projectjazzmine
Engine Management and Tuning
Jun 10, 2008 09:38 AM
