My GSRT dyno sheet
Well i had one and when i was getting it tuned, turning the boost controller **** any way didnt give higher boost so i just took it out. Gonna get a greddy BC soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag »</TD></TR><TR><TD CLASS="quote">Butterflies disabled? so are they stuck open or shut? </TD></TR></TABLE>
Obviously they are open otherwise it would rob power...
Why is it that people think IABs rob power at any rpm? They actually help make a bit of low-end power. Its like all of HT has been brainwashed into thinking that higher flow ALWAYS equates to higher power. In the case of the p28, they should be open/removed, obviously.
Anyways, decent power from 7psi. About on par with my bro's last teg, drag kit/fmu at 7psi.
Bump for my friend! Well, having working butterflies in a forced induction setup wouldnt really help anything.At least we dont think so, i might be wrong but they are good for NA. But he's plannin on getting a single stage manifold anyways sometime soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reddohcvtec »</TD></TR><TR><TD CLASS="quote">Well theres no vac, line hooked to it so i guess the pressure would keep them open. Or closed, i dunno..</TD></TR></TABLE>
Yes no vac source will put the butterflies in their default position which is open. I originaly thought you meant the entire system was removed. By disabling the butterfly valves, your losing midrange and gaining no top end. Removing the butterflies is what gains top end power because your eliminating 4 little throttle plates from the path of each runner.
It says you have a crushed bent exhaust too? Good numbers for the exhaust.
I have a very similar setup, and im hoping for numbers around there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">
Yes no vac source will put the butterflies in their default position which is open. I originaly thought you meant the entire system was removed. By disabling the butterfly valves, your losing midrange and gaining no top end. Removing the butterflies is what gains top end power because your eliminating 4 little throttle plates from the path of each runner.</TD></TR></TABLE>
It's very simple to add IAB control to a p28, which im going to do. I'll post up numbers when it gets dyno'ed.
so vac line on actualor = vaccum (butterflies closed all the time)
and vac line off actualor = no vaccum (butterflies open all the time)
is that right?
is that right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcvtecpower »</TD></TR><TR><TD CLASS="quote">nicely done by reddohcvtec and gsrdriver on the install too, i mite add.</TD></TR></TABLE>
lol thanks
Yeap i belive that is right. With no vac line attached, default for the butterflies is open.
lol thanks
