Exhaust 2.5" or 3"
Old May 18, 2004 | 06:18 AM
sway892's Avatar
Default Exhaust 2.5" or 3"
I have a 2.5" downpipe, should I use 2.5" or 3" exhaust piping.
Old May 18, 2004 | 06:30 AM
JDubya's Avatar
Default Re: Exhaust 2.5" or 3" (lexvdub1)
3" will yield better gains.
Old May 18, 2004 | 06:40 AM
sway892's Avatar
Default Re: Exhaust 2.5" or 3" (ALL MOTOR LS)
But someone told me that with 3" exhaust I might get boost creep.
Old May 18, 2004 | 06:44 AM
Teg4e's Avatar
3" is also loud as ****. How much power are you planning on making?
Old May 18, 2004 | 06:52 AM
JDubya's Avatar
Default Re: Exhaust 2.5" or 3" (Teg4e)
I thought boost creep was dependant on wastegate placement?
Old May 18, 2004 | 07:28 AM
quikB18B's Avatar
I you have the Drag manifold, most people that upgraded to 3" resulted spiking issues.
I'd go with the 3" or you could go with the Greddy PEII(2.75) it would yield good gains and be a little quiter than 3".
Old May 18, 2004 | 07:40 AM
sway892's Avatar
I plan on making between 250-280, I also running stock internals and
stock clucth
Old May 18, 2004 | 07:43 AM
sway892's Avatar
Default Re: Exhaust 2.5" or 3" (quikB18B)
I do have a Drag 3 turbo kit and it comes with 2.5" downpipe.
Old May 18, 2004 | 07:54 AM
FwdCivicHatch's Avatar
some people had boost spike due to a 3" downpipe and 3" exhaust. Don't think that your 2.5"DP will allow for much boost creep.....check around in the search though. Do you already have an exhaust or do you have to buy one either way???
Old May 18, 2004 | 01:58 PM
Teg4e's Avatar
Default Re: Exhaust 2.5" or 3" (FwdCivicHatch)
I'm running a Tial wastegate off a DRAG manifold with the DRAG 2.5" downpipe to a 3" Thermal exhaust. I have only slight boost creep, about a .5 psi change.
Old May 19, 2004 | 06:30 AM
.5 is nothing, but since you already have 2.5DP and 3"Exhaust, leave it that way
Old May 19, 2004 | 08:59 AM
dunkd's Avatar
the best turbo exhaust is no exhaust...
Old May 19, 2004 | 09:28 AM
Charlie Moua's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lexvdub1 &raquo;</TD></TR><TR><TD CLASS="quote">I do have a Drag 3 turbo kit and it comes with 2.5" downpipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lexvdub1 &raquo;</TD></TR><TR><TD CLASS="quote">I plan on making between 250-280, I also running stock internals and
stock clucth </TD></TR></TABLE>
dude we're on the same damn boat. what setup are you looking to run?
I'm going .... stock b18c + apexi turbo kit + Uberdata
235whp and 175tq @ 7psi
280whp and 205tq @ 10psi
300whp and 230tq @ 12-14psi
The apexi kit has a 2.5 downpipe
Now i'm thinking about going with the Greddy SP2 which is 60mm.... about 2.35ish
what do you all think?
Old May 19, 2004 | 02:03 PM
sway892's Avatar
Default Re: (Charlie Moua)
I'm planning on the Drag 3 kit with 2.5" piping and stock clutch and stock
internals
stock P72 ecu
Death_to_Thieves
Feb 21, 2008 04:42 PM
Wonk Unit
Jan 4, 2007 05:34 PM
GetawayInMoscow
Dec 12, 2005 09:46 PM
aaaallll04
Dec 23, 2003 08:16 AM
Timmayeg
Dec 12, 2002 09:47 PM
