Mitsubishi turbo questions..?
Old Jun 28, 2006 | 11:21 PM
bag's Avatar
bag
Default Mitsubishi turbo questions..?
1. -is this a 14b or t25?
2. is there a t3 to mistubishi adapter? cause i have manifold with t3 flange and dont want to have to buy another..
3. what is the stock boost set on this turbo? i searched and found it was 9psi? is that true if so who makes a spring to lower the boost to around 3..?
4. for the water lines where is a good place to tap into? somewhere on the intake manifold?
5. do i need an oil restictor with this turbo?
Thanks in advanve
Old Jun 29, 2006 | 12:44 AM
bag's Avatar
bag
Default Re: Mitsubishi turbo questions..? (bag)
ok i found a t3-t25 adapter from bmc but still need the other questions answered..
Old Jun 29, 2006 | 01:57 AM
teamlegacy's Avatar
What year DSM is it off of? Any close up pictures? I have a T25 sitting next to me, that's why I ask.
Old Jun 29, 2006 | 03:18 AM
Adriano's Avatar
Default Re: Mitsubishi turbo questions..? (teamlegacy)
It's a 14b turbo. You dont need to run the water lines. The boost is set at 9 psi, and you cant change the spring to lower it.
Adriano
Old Jun 29, 2006 | 04:15 AM
bag's Avatar
bag
Default Re: Mitsubishi turbo questions..? (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">It's a 14b turbo. You dont need to run the water lines. The boost is set at 9 psi, and you cant change the spring to lower it.
Adriano</TD></TR></TABLE>
Yeah thanks, im a ****** idiot...Of course its a 14b,,i completly forget how different they looked from the t25 ....
thanks for the answers but what about an oil restrictor? do i need one?
Old Jun 29, 2006 | 01:57 PM
bag's Avatar
bag
p
Old Jun 29, 2006 | 02:42 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bag &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the answers but what about an oil restrictor? do i need one?</TD></TR></TABLE>
No need for oil restrictor. And get a close up shot of the compressor side, a 13g looks similar to a 14b from far away. (Or you could get lucky and it's a 16G)
Old Jun 29, 2006 | 02:49 PM
bag's Avatar
bag
Default Re: Mitsubishi turbo questions..? (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
No need for oil restrictor. And get a close up shot of the compressor side, a 13g looks similar to a 14b from far away. (Or you could get lucky and it's a 16G) </TD></TR></TABLE>
Ha,,i wish i could get that lucky with a 16g...But im pretty sure its a 14b cause guy said it came off "his boys" 5spd gsx eclipse but was unsure the year..
im just curious about the oil restrictor cause i see so many people having issues..So the turbo has one built in?
Old Jun 29, 2006 | 05:40 PM
Everyones Hero's Avatar
That looks identical to the setup I picked up awhile back. Sidemount & TD04 14G turbo.
My stock wg was at 7psi.
Old Jun 30, 2006 | 06:51 AM
97grnrs's Avatar
Default Re: Mitsubishi turbo questions..? (Everyones Hero)
i run a 14 B now... im usin a restrictor.. i doubt if u need to but i did to be safe. does it say TDO5H on the side?
Samuels
Feb 12, 2007 11:11 AM
RACEPAK
Dec 6, 2005 01:48 AM
mrx
May 12, 2004 11:20 AM
curt801
Dec 11, 2003 06:24 AM
jdmtegxsi
Jan 23, 2003 08:23 PM
