the most messed up fuel problem
Old Jun 26, 2006 | 08:43 PM
B18 CYA's Avatar
Default the most messed up fuel problem
so, I have an aeromotive a1000 fuel pump. When I slowly let go of the clutch to start off in 1st, the fuel pressure drops to 0 and engine dies from starvation of fuel. IT just returns freely into the tank. When I am driving, it randomly drops fuel pressure also.
I change out my Paxton FPR to an Aeromotive FPR and same ****. Changed out injectors and put my stock ecu back in, same ****. The fuel pump is constantly running, its just that it quiets down when this happens since the fuel is flowing through freely and returning back into the tank.
An yone know or experience what the problem is? The fuel pressure is not steady, its bouncing around non stop. pissing me off already. It had shitty *** wiring done to it originally so when I got it dynoe'd, we hooked it up directly to a battery. Made 403 whp and 264 ft lbs tq. So then I wired it with 8 guage wire to a relay which gets triggered by the main relay and it seems that ever since then its been acting up.
Old Jun 26, 2006 | 09:12 PM
B18 CYA's Avatar
on the fuel pump? or what. cuz all the grounds on it are 8gauge. and when I ahve it wired directly to a battery, it does the same thing.
Old Jun 26, 2006 | 09:23 PM
B18 CYA's Avatar
yeah i blew the fuel filter out with a blower but it would be nice to change it out and see. highly doubt its the issue though.
its wierd though. its like the engine loses fuel pressure and it just cycles back into the tank. got me stumped and makes me just wanna sell all my **** already. non stop working on it.
Old Jun 26, 2006 | 09:24 PM
Synapse's Avatar
filter-check for sure
You need to get a volt-meter and watch it as you drive. Especially with big pumps, every volt dropped means plenty in terms of volume sounds electrical, could be a bad battery? Or something that is sinking the power
Old Jun 26, 2006 | 09:28 PM
B18 CYA's Avatar
yeah, when I even connect it to a battery in my trunk it does the same ****. I hard wired it to a battery to see if my alternator or battery was the problem, and same thing. I'll try tomorrow with a voltmeter and see how it is.
Old Jun 26, 2006 | 09:43 PM
theinfamouskonrad's Avatar
Default Re: (B18 CYA)
aeromotive recommends using their voltage regulator with the a1000 if it's going to be used over 30min of driving. Idk if it's true or not or if you really need to use one since i never used the a1000. I used the eliminator for long periods of time without a regulator and it seemed to work fine.
Old Jun 27, 2006 | 08:02 AM
B18 CYA's Avatar
bump. why would it be losing fuel pressure and just return back into my fuel tank?
Old Jun 27, 2006 | 10:26 AM
quicksilver1689's Avatar
i ♥ snails
Unstable voltage and/or a bad ground connection might be the culprit but not for sure. Check the fuel system completely for any obstructions and the return line.
Old Jun 27, 2006 | 10:53 AM
B18 CYA's Avatar
will try that. It's a paxton FPR, but i borrowed my friends Aeromotive FPR yesterday and tried it out and same ****.
I'll try a different vacuum source and a different ground. Doubt its hte vacuum though since it just started doing that not too long ago.
Old Jun 27, 2006 | 12:16 PM
DRAGLS's Avatar
its the pump.
Old Jul 5, 2006 | 07:46 PM
B18 CYA's Avatar
Default Re: (DRAGLS)
well just replaced the pump with an SX Performance 18203 and same ****...damn im stumped
B18 CYA
Aug 17, 2006 03:29 PM
B18 CYA
Jul 7, 2006 04:11 PM
B18 CYA
Jul 7, 2006 03:52 PM
iNetForce
Nov 13, 2005 08:27 PM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
