how did everyone weld, or bolt on there oil return line fitting?
Old Jun 26, 2006 | 04:39 PM
skiwithcars's Avatar
Default how did everyone weld, or bolt on there oil return line fitting?
i hav tried a couple ways already and hav hed numerous leaks. i was wondering what everone did, weld a bung, hondabond a return line flange with AN fitting already on it, or just JB weld a brass fitting on it, or watever. i just wanna know what works best, these oil leaks are killin me
Old Jun 26, 2006 | 04:42 PM
AbitAvenger's Avatar
weld
Old Jun 26, 2006 | 06:07 PM
N20civicB18's Avatar
Default Re: how did everyone weld, or bolt on there oil return line fitting? (skiwithcars)
I braised (sp) it? I was going to tig it but last second I thought that braising it would be better, I am glad I did.
Old Jun 26, 2006 | 06:10 PM
VTcivicHB's Avatar
yeah jb is not holding it for me either
Old Jun 26, 2006 | 06:14 PM
Qwik_XR's Avatar
steel piece of pipe (nipple) about 2" long, drilled the hole high in the pan-side, thoroughly cleaned the out/inside of the pan, positioned the "nipple" and tacked it in with a MIG. Ensured proper alignment/position, then welded it completely around, from the inside, then as much of it around as i could, on the outside..
no leaks..
Old Jun 26, 2006 | 06:15 PM
delslo93's Avatar
Default Re: (VTcivicHB)
i drilled the hole just big enough so i could basically screw the brass fitting i got from a hardware store into it. Then I jbwelded it nice and made sure it was dry before putting it back on. Never had a problem with mine. I know I'm cheap.
Old Jun 26, 2006 | 06:19 PM
Default Re: (delslo93)
yah, thats wat i did, but it didn;t hold and i got leaks everywhere. i am thinking of just bolting on one of the flanges that has a -10 AN fitting on it and just using that. but welding the flange is not goin to work because it is aluminum, while the pan is steel. unless i could find a steel flange.
Old Jun 27, 2006 | 08:07 PM
Default Re: (Mr Wonderfull)
a brass one? would that work well? im afraid of it leaking throu the thready like the last one did. i did use teflon tape
Fatty_1775
Jul 30, 2006 08:04 PM
WildChild
Sep 15, 2005 08:35 PM
LilCivic04
Aug 18, 2005 08:12 AM
reignofchaos
Jul 27, 2003 10:34 AM
Trigun
Jun 17, 2002 10:47 AM
